Long tube header results!
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    i did not know that, thanks. This might save the the extra cost of getting a y-pipe
    • Stu Mc
      • 4083
      Nice to see your dyno plot, I always wanted to a comparison with those headers.
      Your power seems to drop off early though, it peaks at 5800 and plummets; that's not characteristic of these motors at all.
      • ed94r
        • Mar 2004
        • 382
        Ya, I hear ya on the fall after 6K. I've been thru the ringer trying to figure out why...compression tests (239high,233 low), vanos solenoid, software, speed sensor wire, etc...*I* think it's a cam timing issue, although the guys at the shop say it's not possible as the cams can only be locked down one way. Another opinion is the actual VANOS, but I get no codes for mechanical malfunction, and the switch over happens approximately where it should. Any opinions Stu?
        I'm gonna dyno it with the new midpipe mod, cuz it feel's like a totally different car, *especially* from midrange to limiter. If the curve doesn't change, I'm going in for surgery.
        Ed
        1988 E30/S50...now with S52; Track
        1994 Miata R; ES Solo2
        1998 Lexus LX470; Wife (Slee'd anyway)
        2002 BMW 530i; A+ Commuter
        2002 BMW 325iT; Sport/Premium 5-speed
        2011 21' EconoTrailer
        • Jason89i
          • Sep 2004
          • 875
          Originally posted by ed94r
          .........*I* think it's a cam timing issue, although the guys at the shop say it's not possible as the cams can only be locked down one way.
          ed -
          i doubt its the vanos unit. vanos engages around 2500 and disengages around 5500. it helps mid range torque.
          re:cam timing. i installed some m3 cams on my old m50tu. car pulled VERY strong in the upper rpm's. a friend had the m3 cams installed by a local shop. his car pulled harder in the mid, then fell off a bit in the higher rpms. we could never figure it out.....untill we ripped everything appart. the local shop installed the cams around 2deg retarded. dont ask me how or why.
          what cams are you running? the schrick cams SHOULD NOT be installed with the locking tool. they need to be dialed in. i had a buddies car go through this. if installed "straight up," they might have clearance issues. rumor has it.... there was a batch of schrick cams that are off time floating around. we happend to find (2) of the (2) sets to be off time with the locking plate. and sunbelt.....rumor has it, those are never installed "straight up."
          if you have stock cams, it mmight be worth just double checking.
          cheers, jason
          • aeryk7
            • Oct 2005
            • 616
            Tell me about it i have the damn e36 325 midsection and noticed it was skinnier than the M3 piping. I guess that makes sense though.
            253rwhp
            My Vids(OLD)
            http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
            http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
