Cams
  • DanThe
    • Mar 2006
    • 98
    Cams
    Anybody know if the M50 2.5 non-vanos cams have a higher valve lift than the M52 2.8?
    Im planning on using a 2.8 alloy block with my 2.5 non-vanos head, just trying to find out if the pistons are likely to hit the valves
  • PiercedE30
    • Apr 2005
    • 4220
    I know on the stock nonvanos intake cam, i believe the valve lift is like 10.5 or 10.2 mm or something (whatever they measure lift in)
    My 2.9L Build!
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      Stock NV M50 cams are:
      Intake: 244 w/ 9.7 lift
      Exhaust: 244 w/ 9.0 lift
      You should be fine unless you plan on shaving the head to increase compression.
      • DanThe
        • Mar 2006
        • 98
        OK, thanks for that
