What kind of power should I expect to have if I build up an alluminum block m52 with an s52 crank? From what I've been reading, that should put the total displacement at 3.1L if I keep the stock bore size.
Would I be able to use the stock pistons, or would there be clearance issues due to the longer stroke?
The motor will be built to OBDI, will have Schrick cams, and a euro HFM
Does this sound like a good idea, or am I just building a timebomb?
Would I be better off building my s50 to 3.2L? I'd like to keep it as light as possible, but don't want to sacrifice too much power or durability.
-Erik
-Erik
