I'm with tjjartge on this one. For whatever reason, the dme is deciding not to turn on the heater. It's not that the dme is trying to turn it on and there's no voltage/power. I'm not sure where or how this could be a power/gnd/relay wiring issue unless there is another pwr or gnd terminal that needs to be wired to the dme - or the dme is not seeing a sensor signal.
As for the temp sender, I don't think it's there. The cluster and dme temp sensors are different - I'm running the stock s50 engine temp sensor that feeds the dme. I've only swapped out the sensor which feeds the instrument cluster. As far as I know, the dme engine temp sensor is self-contained in the harness.
I'll double check my car for codes, but that last time I checked I got the "no codes" code. Can anyone confirm if they are getting an o2 sensor code?
I just read Jason's comments on the other thread. If I'm understanding this correctly, the e36 fuel pump relay normally powers the e30 green/violet wire which in-turn goes to the fuel pump and possibly some other place which has something to do with the e30 o2 heater? It's this alternate path which must somehow work it's way back to the e36 dme and then doesn't allow the dme to turn on the o2 heater relay? Or, maybe that backfeed voltage winds it way to the o2 heater relay and maybe the dme is trying to switch it's ground signal, but can't!? Jason's fix sounds like it isolates the fuel pump and e30 o2 heater on the green/violet wire - so that the e36 fuel pump relay only feeds voltage to the fuel pump and nothing else? I guess you're looking on e30 schematics to find alternate paths on the green/violet wire.
