Engine Rebuild Supply's
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    Well, Im finally looking through the engine with a european mechanic. hes explaining how everything works in the engine and hes helping me do what it needs. he told me they should have a gasket kit.
    Head Set (Bottom Head and up)
    Conventional Set (Everythiong below the head)
    Does anyone know if this is true. it would be easier to order from the dealer or worldpac instead of ordering a million gaskets and orings.
    thanks!
  • FredK
    • 14761
    Yes. Worldpac has a head gasket set, which includes most all gaskets, including head gasket, intake manifold gaskets, TB gaskets, Vanos o-ring, heater hose fitting gasket, thermostat gasket, exhaust gaskets (both at downpipe and at head), etc. The bottom end gasket set includes the gaskets for the timing case, the oil pan, the oil sump, the rear main seal, etc.
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      sweet, now are they aftermarket or OEM? i was told not to get aftermarket.
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        Probably a mix of what's available.
        Honestly.. some of the newer aftermarket gaskets have some improvements over the OEM.
