brake booster vacuum valve
  • cahomey
    • Mar 2004
    • 1201
    On my m20 there was like a valve/regulator in the hose that went from my intake manny to booster. I have also seen these on e36's.
    On my m50 I just have a straight hose going to the booster. My question is do I need to have that valve?
    7 + 8
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • Van Westervelt
    • 9365
    7/8 are the same unit, just different shapes, one is at 90* other is straight. You dont need both.
    • cahomey
      • Mar 2004
      • 1201
      So are you saying I NEED one of them?
      • Van Westervelt
        • 9365
        You should have one on there yes. Most time its attached to the booster, otherwise the line has nothing to go onto. How do you have it on there without one?
        • cahomey
          • Mar 2004
          • 1201
          Im using the fitting from the stock booster.
          • Jason89i
            • Sep 2004
            • 875
            Originally posted by cahomey
            On My question is do I need to have that valve?
            if your engine dies while you are driving....do you want power assisted brakes? check valve holds vacume in the booster even when vacume is not present in the manifold. i vote yes. (ever try to stop an e30 without power assisted braked? its very difficult.)
            cheers, jason
