Levelling switch in oil pan
  • raimo
    • Nov 2005
    • 36
    Well I bought this m50b25 engine from a '91 525i. it had a levelling switch in the oil pan (#11)
    http://www.realoem.com/bmw/showparts...98&hg=11&fg=10
    but the oil pan didnt suit my 325iX -> 325i rwd m50 conversion, so i swapped it for a oil pan, that came from a 325i. but the new oil pan doesnt have that switch.
    http://www.realoem.com/bmw/showparts...17&hg=11&fg=10
    what is that switch for ?
    is the switch in the 3series engines in somewhere else or can i just leave the plug in my harness unplugged ?
  • KangamangusDriver
    • Aug 2005
    • 1870
    I believe it is for the dummy light when you run low on oil.
    I bypassed mine, machined a aluminum dummy plug to fit in place of it.
    • trent
      There is a factory plate that will also go there.
      • Mike B.
        • Jan 2006
        • 987
        I wired it into the check panel.
        • raimo
          • Nov 2005
          • 36
          So no need for it. Im going to install an oil pressure gauge anyway, so when theres no oil, there cant be any oil pressure anyway.
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            does the e36 motor harness have a low oil plug?
            • 1990m3
              • 1180
              i just left mine there since I had no suitable alternative to replace it. Don't plug it in, no problems.
              • LINUS
                • 2422
                Are you expecting to run a pressure sender there? - if so, I've never heard of being able to pull a pressure signal from an oilpan. No pressure there. Great spot for an aftermarket temp sender, but you need to come up with a solution for pressure sending up by the oil filter - you get pressurized oil there.
                It's not how you handle the good times, but the faith you keep in the bad that defines you.
                • raimo
                  • Nov 2005
                  • 36
                  No, not from there.
