m50 fuel rail without FPR?
  • EtaSport
    • 2853
    So I went to put the manifold together and I slipped the injectors into place and then noticed there was no fuel pressure regulator on the fuel rail. Very odd I thought. I have seen 2 other m50 rails and both had regulators on them. The diagram for realoem shows a pressure regulator. Any way to make it work, or anyone every heard of/seen it?
    Old and improved:
  • Jason89i
    • Sep 2004
    • 875
    Originally posted by EtaSport
    .......noticed there was no fuel pressure regulator on the fuel rail. Very odd I thought. ........ Any way to make it work, or anyone every heard of/seen it?
    yep, must be a 95 motor. i saw it with my first car. the fpr was actually at / near the e36 gas tank. i too, was perplexed. just add an adj. fpr on the fuel return hose. cheers, jason
    • Skafrog
      • 1732
      Make sure you plug the hole in the intake manifold that goes to the FPR if you dont use a factory FPR on the fuel rail.
      OBD2 cars had the FPR by the 3/2 valve on the underside of the car.
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
      • aeryk7
        • Oct 2005
        • 616
        Or just go get a used rail for $30 or less dollars
        253rwhp
        My Vids(OLD)
        http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
        http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
        • EtaSport
          • 2853
          its probably from an obd2 car, or the aformentioned 95. I'll probably just get another rail. the project has been pushed back another 2 weeks so I can wait on parts. Thanks
          Old and improved:
