S50 Flywheel on a Factory E30 Transmission?
  • BMW_TUNER
    • Jul 2006
    • 1386
    I just found out that the S50 engine I purchased has a flywheel that is in excellent condition. I understand that the S50 flywheel is larger and may be a better choice. Is it possible to keep the larger flywheel or is it to large to fit in the bellhousing? I really like my factory trans and it shifts like butter so I dont want to replace it. Any advice is much appreceiated.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
  • trent
    the dual-mass flywheel is a piece of crap. dump it.
    • raimo
      • Nov 2005
      • 36
      will a single mass flywheel work with a m50/s50 engine ?
      • erik325i
        • Jan 2005
        • 3567
        yes
        -Erik
        • trent
          Search. I am using an 8lb flywheel. Revving is great with it.
          • tjhartge
            • Jun 2004
            • 86
            yes it will
            a friend of mine used the flywheel from a euro 323i, revs are so light
            flywheel matched with the appropriate clutch set
            • matt
              • 3732
              Originally posted by tjhartge
              yes it will
              Matched with the appropriate throwout bearing and clutch slave cylinder.
              The answer is yes, it will fit inside the bellhousing.
              Matt
              • raimo
                • Nov 2005
                • 36
                which throwout bearing and clutch slave cylinder are compatible with a m50 and singe mass flywheel ?
                  • 37834
                  I was about to post this question aswell, sort of.
                  I am running a S50 and want to run an E30 260 trans. Which flywheel and clutch will best fit my application, something that needs no modification.
                  Grover Beach, California
                  BimmerHeads.com
                  • DanThe
                    • Mar 2006
                    • 98
                    Im using an M20 shaved flywheel and clutch with my M50/E36 box with no problems, standard E36 slave and release bearing.
                    The clutch was used and ive done over 10,000 miles with it so far
