m50 exhaust manifold's
  • cahomey
    • Mar 2004
    • 1201
    I noticed once I finally got m50 mounted to the sub frame the front exhaust manifold was VERY close to the sway bar, subframe & motor mount.
    My exhaust guy told me it was a little difficult because it was so close.
    I also noticed that the rear manifold was shorter then the front.
    So my question is, Would it have been possible to switch the front and back manifold's so they have a bit more clearence? Or is the front manny to long to fit in the back?
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    i thought about doing it but when i visualized it in my head i would end up with another problem. I have the obd2 manifolds, and i think it would have caused another clearance issue, probably with the firewall
    • aeryk7
      • Oct 2005
      • 616
      Wont work the rear ones if used on the front will be aiming directly into the engine mounting arm as in it doesnt fit at all
      253rwhp
      My Vids(OLD)
      http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
      http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
      • cahomey
        • Mar 2004
        • 1201
        Yea, I sort of realized it wouldn't work after I posted. But oh well.
        • browntown
          • Jun 2004
          • 3524
          I believe treehouse touts this problem as a reason to use their eyeball cabs. having problems getting to their item description to check. seems familiar though.
          • permit
            • Mar 2005
            • 3363
            You're having this problem with OBDI manifolds? Jesus, can't imagine what you'd be saying if you had the OBDII ones (which I hope you do). OBDII ones nearly kiss the subframe, but you can still can an exhaust system installed, it's just a tight fit.
            • cahomey
              • Mar 2004
              • 1201
              Yea I have OBD-I manifolds. They are SO close.
              I would rather get headers then the OBD2 manifolds.
              EDIT: Which headers are the best to get for m50 e30's?
              • aeryk7
                • Oct 2005
                • 616
                Maybe two front manifolds would work? probably would end up touching the firewall/transmission tunnel area so n/m.
                253rwhp
                My Vids(OLD)
                • tjhartge
                  • Jun 2004
                  • 86
                  Over here, RHD cars can only use the OBD-2 manifolds as it needs to clear the steering shaft. The manifolds need to be cut and weld to get it to clear the firewall and steering shaft. For LHD cars, either manifolds can be used, but the OBD 1 manifold are alot heavier
                  • raimo
                    • Nov 2005
                    • 36
                    i plan on doing custom primaries from stainless. i have engine from a 525i
                    • permit
                      • Mar 2005
                      • 3363
                      You live in Cali, don't get headers. I made that mistake.
                      • matt
                        • 3732
                        Edit: Nevermind
                        • cahomey
                          • Mar 2004
                          • 1201
                          OBD-II Manifolds it is... lol damn. headers look so pretty.
                          • trent
                            If I was to do this, I would get the car refereed with the stock manifold. After you get the sticker, I would change, then when you go to smog, you can just say that, on the referee said they were fine :)
                            TTT
                            • cahomey
                              • Mar 2004
                              • 1201
                              TTT
