Euro S50 and Brake Boosters
  • Mike B.
    • Jan 2006
    • 987
    #121
    Lee,
    With the dual master in a single body setup, the spacing between the two shafts is too narrow for the integration of a balance bar. There would not be enough adjustment before you end up with binding. The only way to control bias with this setup is with an adjustable bias valve plumbed into the rear brake line.
    • Mike B.
      • Jan 2006
      • 987
      #122
      Originally posted by 1990m3
      beautiful! Do you ever make it out to the track? I'm in your area and would love to see your setup sometime.
      I'll be running the full course at Autobahn with AMS (of EVO fame) on April 28th.
      • 2002maniac
        • 4260
        #123
        I'm not even planning on a swap in the near future, but here's my manual brake adapter that I made in my spare time at work. Unfortunately I cant make more to sell (even though the cost would be prohibitively high), my boss doesnt want me using his machines for side jobs that put money in my pocket. It started out as a 5" round 6061 billet.
        • Mike B.
          • Jan 2006
          • 987
          #124
          Nice! Why the extended length?
          • 2002maniac
            • 4260
            #125
            just so I wont have to make new brake lines. If I were to make another one I would just make it out of 1/2" plate and have the master right on the firewall. it would be much less machining.
            The bracket is 1/4" shorter than the stock booster and the master is moved 1.25" upward to allow a straight shot for the pushrod from the relocated pickup point on the pedal.
            • Mike B.
              • Jan 2006
              • 987
              #126
              Actually, if you move the m/c up one inch (along with the pickup point on the pedal) the pedal ratio goes from 4:1 to 6:1.
              6:1 is just about perfect for a manual setup.
              • 2002maniac
                • 4260
                #127
                mine's actually about 7.25:1
                I think I'll try a smaller than stock porsche master cyl if it will push enough fluid. That should also help with pedal effort.
                • Mike B.
                  • Jan 2006
                  • 987
                  #128
                  You should have no issues with pedal effort on the stock M/C with a 6:1 or greater pedal ratio.
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    #129
                    Interesting discussion.
                    1:6 pedal ratio on a stock MC. Is "stock" the 21mm 325 master or the 23,8mm M3?
                    Mike, what MC will you run on your M3 with front 4 pots?
                    Lee
                    massivebrakes.com
                    • Mike B.
                      • Jan 2006
                      • 987
                      #130
                      Lee,
                      Take a look at this link - http://www.stoptech.com/tech_info/Pe...ster-Guide.pdf
                      It provides a lot of info on setting up a manual system.
                      I'll be using dual 3/4th (19mm) masters with your 13" rotor 4 pot (1.63" piston) fronts and E30M3 rears. My calculations (along with input from a Tilton engineer) show that I shouldn't even need a bias valve with this setup.
                      • 2002maniac
                        • 4260
                        #131
                        Lee
                        The ratio will stay the same regardless of MC used. What the pedal ratio measures is how far you have to move the pedal to move the master cylinder. The higher ratio the greater mechanical advantage you have, however, a higher ratio also means longer pedal travel.
                        • Mike B.
                          • Jan 2006
                          • 987
                          #132
                          Update:
                          I am now making pedal clusters with dual masters (or triple w/ clutch) that allow for balance control via cable. It will incorporate most aftermarket M/C's (Tilton, Wilwood, AP, or Girling)
                          • FredK
                            • 14764
                            #133
                            Hm. So the brake MCs sit inside the cabin, then are plumbed through the firewall, just like the clutch MC?
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              #134
                              Very nice. How much?
                              My 2.9L Build!
                              • Mike B.
                                • Jan 2006
                                • 987
                                #135
                                The masters still mount in the engine bay. An additional hole(s) will have to be drilled. I have a template to make things easy for the installer.
