which coolant hose between rear of engine and heater core?
  • hugh jass
    • 2220
    I'm wondering what hose you guys used to connect the heater core outlet on the firewall to the port on the rear of the head? I bought the e36 hose, but it doesn't have the 90 degree bend in it that the etk hose shows. when i try to bend it, it kinks and would obviously restrict coolant flow.
    any suggestions? will the stock e30 hose fit? thanks.
    ______________________
    ex-Chief Operating Officer
    Blunt Tech Industries
    West Coast and Pacific Rim
  • trent
    nm
    • hugh jass
      • 2220
      Originally posted by trent
      nm
      dang!
      • trent
        IIRC I used an E36 hose.
        • equate975
          • Jun 2004
          • 3382
          I used e36
          Rollin' with a Geistkuchen
          • FredK
            • 14747
            I used the M20 hose. I ran into the same problem you did. I bent the heater core pipes a tad as well, to make it easier to access the hose clamps.
            • trent
              I cut and had my pipes tig welded at a better angle for the intake manifold
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                i used a metel 90degree elbow and hose clamped
