Ok, I am in the middle of making my X20 -> C101 adapter. I have been going through the ETM and ended up looking through all 470 some odd pages and was able to find all but two pins. Pin 21 (which is green) and pin 22 (which is green/white). I am using addissimo's pinout in helping aid my progress while double checking it with my harness. According to his chart those pins should be ignition switch (pin 21) and o2 sensor, heater relay (pin 22). Only problem is that I can't find it in the ETM. If someone would could either a) confirm this or b) tell me the etm page number that these pins are on, it would be greatly appreciated.
The harness is for a non-vanos M50 from a 04/1992 automatic E34.
Jon
Jon
