Where to attach fuel rail ground cable?
  • FredK
    • 14763
    At the front of the fuel rail, there is a short (3"?) brown ground cable. Where does this get attached? TIA!
  • browntown
    • Jun 2004
    • 3524
    I don't know from experience, but my *guess* would be to the block, since the block is grounded to the frame, which the neg battery lead is also grounded. Is there a bolt to the block anywhere within the 3" radius of the ground cable?
    • aeryk7
      • Oct 2005
      • 616
      There is a longer bolt that connects the vanos unit to the head, it is also the bolt that hold the hook onto the head.
      #9 bolt
      253rwhp
      My Vids(OLD)
      http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
      http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
      • hugh jass
        • 2220
        anyone know the part # for this strap? i can't find it on the parts diagrams. thanks.
        ______________________
        ex-Chief Operating Officer
        Blunt Tech Industries
        West Coast and Pacific Rim
        • FredK
          • 14763
          Thanks aeryk7! I busted out a multimeter and checked what places were grounds. The engine hook bolt was both a ground and a convenient location for the ground cable.
          hugh jass, are you talking about the ground strap that goes on the ignition coil to ground it? Because the ground cable I'm talking about is attached and is part of the injector electrical harness, right at cylinder 1.
