main relay and ecu working....no fuel or spark.
    well i woulda kept on goin in my previous thread but ive solved my little main relay problem its now working like it should. how ever the fuel pump relay is not clicking on, and the ecu is not grounding the relay either or initialzing the fuel pump..also it is not pumping fuel during cranking. if i remmeber correctly tonytony was having the same problem with his relay ground switch wire to the DME. how does one fix this???
    i took the ghetto route and ground the relays, so when ever the ignition was on the fuel people would always be running. I needed my car to be driving or i would have spent forever or paid someone to do it. if someone has a better resolution please chime in.
      Still waiting for a fix. Anyone?
        what was your fix?
