Getrag 260 vs ZF Tranny
  • 325Projectz
    • Jan 2005
    • 1956
    True, e28 528e manual.
    91 m3
    • DeM3n
      • Mar 2005
      • 1260
      Originally posted by 325Projectz
      If you use a e28 528 manual bellhousing it'll work just fine. I forget which year, but there are very few around.
      Word, that's the bell housing that I'm using with my 265. I think I might just stay with what I have and try to modify my bracket to make it work. Right now I'm using an m20 motor mount with my tranny bracket. However, its starting to vibrate again so I think it might be worn and needs to be replaced. I'll just have to figure something out.
      • Rocla
        • 922
        Since you are running a transmission with separate bell housing, maybe you could machine new mounting to bellhousing and turn the transmission to right position and use all the stock parts.
        Current:
        BMW 320i 2d 2.0 m20 -88
        BMW 325i Cabriolet 2.5 m50 -88
        BMW 316i touring 1.6 m40 -90
        BMW 320i 4d 2,2 m54 -01
        • trent
          stay with your tranny. just build a good bracket, or find a combo of mounts that works. :)
          • DeM3n
            • Mar 2005
            • 1260
            Yeah, I'm trying not to take my transmission completely out. I'll just try to work on that bracket.
            • grib
              • Oct 2006
              • 151
              This was probably the most difficult decision I had when considering the swap. I bought an S52 from a low miles auto car so I have had to source all of the driveline parts. My '87 has only 104K miles on it and the Getrag could use some new seals but is in pretty good shape. I was considering using it for several months, but decided against it.
              I went with the ZF because in the end I believe it will hold more power for longer and leave options for FI open. It allows the stock bracket and an OEM 328/M3 driveshaft to be used with "standard" e21 mounts. (I will be using the UUC Black kit.) The Getrag will require a custom fabricated bracket. I have read that the older 318 driveshafts can be used with it, but I think this is a little iffy on a modded M3 engine. Otherwise you are looking at a custom combination of shafts that will need to be rebalanced.
              FWIW, I contacted both Zionsville and Spec Clutches regarding which driveline to use. I told both vendors that I was looking to be in the ~280-300 bhp range. Spec said that the Getrag 260 (with Spec stage 2, of course) could handle the power, no problem. Zionsville said not to even consider using the Getrag 260 with an S5X engine. BMW did use the Getrag 265 on several 250-300 range bhp EVO M3 models, but I doubt these setups were made with longevity in mind. ;-)
              We have all heard the ZF moneyshift stories, but I'm yet to hear of or read about anyone toasting their Getrag, but it has probably happened. How long will a transmission designed for a ~170 bhp engine last on a 250-300 bhp engine?
              1987 325i Cabrio - SOLD
              2014 Chevy Volt
              2007 FJ Cruiser
              • Lof8
                • Oct 2006
                • 2827
                Why are none of the vendors making a transmission bracket for using the e30 Getrag with an s5x? Has everyone who has used this combo made a custom mounting bracket?
                S50'd
                Originally posted by TDE30
                What is this faggy shit I have happened upon?
                I can always live in a M3. Can't M3 a house.
                • trent
                  Because it isn't that big of deal. I used all stock mounts, and didn't modifiy anything.
                  • Lof8
                    • Oct 2006
                    • 2827
                    Why are some people talking about the fabrication of mounts if you can do it with stock stuff? What combination of stuff did you use, Trent? I'm sure I could find this from a search, but the threads are too damn long.
                    Thanks
                    S50'd
                    • bmws50b30
                      • Aug 2005
                      • 1151
                      Thanks
                      +1 i'd like to know too please
                      1991 330is
                      • Lobstrosity
                        • Aug 2004
                        • 116
                        +2 (although I don't have a dark coloured car with gold mesh wheels in my sig) :)
                        • Lof8
                          • Oct 2006
                          • 2827
                          tranny mount
                          *paging Trent*
                          S50'd
                          • ed94r
                            • Mar 2004
                            • 382
                            I've got 2 years on a S50/260 and Redline MTL. Daily driven and speed shifted on rare occasions (no lift shifts on 2-3 and 3-4). I can say that the 260 with a modified M20 flywheel and a stock E30 M3 clutch (with about 30K hard miles) have survived my ham fists with flying colors. 222/223 rwhp/rwt for what it's worth.
                            The only issue was the shifter moved somewhat to the right at rest compared to stock, which I noticed for about 5 minutes and have subsequently forgotten about. Believe me, this is a non-issue once you drive it more than a day.
                            I don't see why a person would do anything else. It seems to me as a waste of time and $$$ to go with the E36/M trans when the 260/3.73 work so well...and most of us already own the right hardware BEFORE the swap, thus saving nice coin.
                            Most of the spec guys and club racers around here see the 260 as bullet-proof. I am also riding the 260 bandwagon...
                            Ed
                            1988 E30/S50...now with S52; Track
                            1994 Miata R; ES Solo2
                            1998 Lexus LX470; Wife (Slee'd anyway)
                            2002 BMW 530i; A+ Commuter
                            2002 BMW 325iT; Sport/Premium 5-speed
                            2011 21' EconoTrailer
                            • rede30
                              • 4697
                              I have a e36m tranns, correct d-shaft,new m3 clutch, apropriate tranny mount and bushings, and a 325lsd,all from a previous car. Shit, now i am thinking twice. I still think i will go with the setup i already have but i might be switching soon down the road from what i have been hearing. i will see how i like it with new polly bushings and new shift parts.
                              • 1990m3
                                • 1180
                                Some of us started with M42's :(
