Trans question for S52 swap
  • bwh13
    • Jan 2007
    • 437
    OK I was told by a source that the trans from the 318is and 325is (92-95) are basically the same and that either one will work behind the S52. These are the 250 Getrag units. I don't plan on having more than 280-290hp max from this engine and want to make sure I don't have to step up to the 320 ZF box from the M3 or 328is.
    Also can I use the M3/328is 240mm diameter flywheel/clutch in the 250 trans?
  • FredK
    • 14761
    Yes, you can use the M3 clutch with the Getrag 250. It's a common upgrade for E36 non-M vehicles.
    However, I think spending the extra $150 or so on a ZF is a wiser choice--it can take more power.
    • DeM3n
      • Mar 2005
      • 1260
      It can take more power... but it all depends on what you want to do with it. For FI... ZF.... for everything else I think the Getrag will take what ever you throw at it. Plus, its cheaper!
      • matt
        • 3732
        The bellhousing on the 318 250 is smaller... my flywheel didn't fit in it. It fit in the 325 trans just fine.
        As far as I know, they are the same otherwise.
        • bwh13
          • Jan 2007
          • 437
          OK so which flywheel/clutch can I use with the 250? Do I have to use the 318 or will the M3 fit?
          • matt
            • 3732
            The stock M3 clutch/ flywheel should fit, but some aftermarket ones don't.
            • bwh13
              • Jan 2007
              • 437
              Do you know for sure if the stock M3 flywheel/clutch will fit? Anyway to know before I spend the $ on them?
