Throttle problem
  • Bimmer335is
    • Jun 2006
    • 146
    Throttle problem
    I have my e36 throttle cable all hooked up, but when I press my foot on the throttle pedal all the way, the throttle body doesn't open all the way up to the 90 degrees. It opens at most, 40-45 degrees.
  • KangamangusDriver
    • Aug 2005
    • 1870
    You should be able to adjust it at the throttle body, if not shorten the cable.
    That is what I had to do with my setup (shorten it)
    • Bimmer335is
      • Jun 2006
      • 146
      I thought is was a plug and play thing, I never thought I would have to shorten it... Which end did you shorten?
      • Bimmer335is
        • Jun 2006
        • 146
        maybe I'll see if I can adjust the throttle body.
        • Mike B.
          • Jan 2006
          • 987
          Don't adjust the throttle body! No sense messing with something that doesn't need to be messed with. Take a look at the Bentley, they state that you should make the adjustments with the throttle cable and NOT the linkage.
          Just adjust the cable. It has a little screw fixture that you turn to lengthen or shorten the pull. Try that first.
          If that doesn't work just shorten the cable a bit. It's not hard to do. You shorten the throttle body end.
          • equate975
            • Jun 2004
            • 3382
            How far is it supposed to open? Should it be a full 90 degrees? Mine opens maybe 85 degrees or so.
            Rollin' with a Geistkuchen
            • Mike B.
              • Jan 2006
              • 987
              It should be open 90 degrees when the throttle pedal is floored.
              • Bimmer335is
                • Jun 2006
                • 146
                I know not to touch the throttle body... I wouldn't even know where to begin with it anyways. But I already tried to adjust the throttle cable with the screw fixture, didn't work so I guess I will just have to shorten the throttle cable.
                Which end do you guys sudjest I shorten?
                • Mike B.
                  • Jan 2006
                  • 987
                  Shorten the throttle body side.
                  Of course a new cable is only like $25, how much is your time worth? :)
                  • japspecvr6
                    • Apr 2005
                    • 602
                    any body has pics......cuz im going thru that same thing.........
                    M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                    • Bimmer335is
                      • Jun 2006
                      • 146
                      I'll post a picture of what I did tonight.
                      • japspecvr6
                        • Apr 2005
                        • 602
                        please........cuz i dont know if has two gornets.....or waht.......
                        • skuyler
                          • Jan 2006
                          • 72
                          • Bimmer335is
                            • Jun 2006
                            • 146
                            here's a picture of what I did, notice the wire connection crimped around the throttle cable.
                            • japspecvr6
                              • Apr 2005
                              • 602
                              thanks it help alot......but i didnt crimp anything.........if you screw the back end it will get tight.....i just didnt know where to push the gronet in at...........Thanks ALot man..........
