how many parts will it have that are good for an M50 swap?
If I buy a stick 93 525i,
Tags: None
1988 e30 alpine white vert 5speed
1987 e30 325 eta
1983 e28 533
2001 x5 4.4l
1997 e36 M3 Alpine white 5speed
1991 Jeep XJ I6 4.0Comment
E36 and E34's have the same tranny (M50's, S50's have a ZF), so you can use your existing transmission bracket and 5-spd driveshaft.
Schneller is right though, if you have a 3.73 diff you will want to change it out (3.46 or 3.25 are nice) since 5th gear in the e36 tranny is 1:1.Comment
those are all OBD II and you would need OBDI m50 parts. This assumes that it is an iron block M52 from the earlier e39 528i and not the aluminum dual vanos M52tu which cannot be converted to OBDI.
It is possible to install the engine with its OBDII components. A couple people here have done it, but there is a good deal of hp to be gained from the OBDI conversion.--WillComment
Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
