AC Bracket Removal
  • ZiMMie
    • Jun 2004
    • 968
    AC Bracket Removal
    Jst wondering people that have done Swap with out ac, how do u remove the bracket? Ive got the front 4 bolts but there is 2 more that is right beside the crank pulley does it has to be removed in order to get to it??
    thanx
    www.stancefactory.com
  • Jean
    • 18228
    Is the bracket different on the 325 ?
    Mine was attached to the block with 3 bolts-
    http://www.briangt.com/gallery/album...acbrackets.jpg
    http://www.briangt.com/gallery/album...ginemount2.jpg
    • Bimmer335is
      • Jun 2006
      • 146
      If I remember correctly, I had to remove the crank pulley to get to all the bolts. Just take the crank pulley off along with the ac pulley and then put the crank pulley back on and torque the bolts back to spec. Should be fine.
      • ZiMMie
        • Jun 2004
        • 968
        i thought i could get away without removing the crank pulley i gues not.
        talking about pullies, wat do u guys think about Underpullies on ebay?
        E.g. http://cgi.ebay.com/ebaymotors/UNDER...spagenameZWDVW
        • SchnellerVert
          • Sep 2005
          • 3948
          Buy from a reputable source, that piece would make me nervous.
          • trent
            remove the crank pulley. Its easy only 6 bolts.
            • matt
              • 3732
              Do not use that pulley. Replace the accessories, not the crank pulley.
              • equate975
                • Jun 2004
                • 3382
                I don't recall exactly how it went together. But I know I did not take the crank pully off.
                Rollin' with a Geistkuchen
                • MikeE30325i
                  • 2356
                  yeah i believe i took the four bolts off on the passenger side of the block and the bracket came right off. though my car was dipped into the fiery pit of hell and brought back out.
                  • e30_kid89
                    • Apr 2006
                    • 489
                    ur sorta annoying, get the fuck outta here u dont even have a 24V e30.......mike like i said since my compresseor was already gone i remember i removed hte 4 bolts that go to the side of the block, and then the 2 that are damn close to the crank pulley.....i did this without even touching the wheel...no removal needed for me
                    • NZM50SWAP
                      • Feb 2006
                      • 75
                      Yeah man you have to take the crank pulley off to get at them
