Transmission brace???
  • e30ryan///m3
    • Dec 2005
    • 249
    Hi guys,
    I am almost ready to mount the s50 into my e30 m3. One thing I am having trouble with is the e30 m3 transmission brace doesn't seem to fit at all with the e36 m3 transmission. I have searched for this and can't find anything that sais I shouldn't be using the stock e30 transmission brace???? Was the transmission brace in the e30 m3 different? I think I'm going crazy! If anybody has run into this please let me know.
    Thanks,
    Ryan
    1988 M3 (Diamondshwartz)
    2004 M3 (SilverGray)
  • matt
    • 3731
    You have the brace backwards???
    • Jason89i
      • Sep 2004
      • 875
      Originally posted by e30ryan///m3
      Hi guys,
      ........ is the e30 m3 transmission brace doesn't seem to fit at all with the e36 m3 transmission. I have searched for this and can't find anything that sais I shouldn't be using the stock e30 transmission brace???? .....
      Thanks,
      Ryan
      ryan - the e30 m3 and 325's have different parts. the m3 has an aluminum trans support, hte 325 has a stamped steel one. cheers, jason
      • e30ryan///m3
        • Dec 2005
        • 249
        I have the ZF transmission for the swap and I've heard that you have to fab up a cusom brace for the ZF tanny to work? Does anybody know if I can use a stock part so that I don'thave to fab up a custom brace? does anybody know if the stock e36 tranny brace for a ZF transmission will work in an with the s50 swap in an e30 m3???? I know that people use the getrag tranny with the stock e36 trans brace but why is the ZF trans so different???? Thanks for any help!!!
        Ryan
        • Jason89i
          • Sep 2004
          • 875
          I have the ZF transmission for the swap and I've heard that you have to fab up a cusom brace for the ZF tanny to work? .........Ryan
          nope. just use the e30 325 tranny brace. will work with the e36 325/316 getrag or the e36m3 zf. if your using the zf, dont forget the zf shift carrier, shift linkage.
          custom e30 325 bracket only needed for the e30 getrag.
          cheers, jason
            • 37828
            cheers, jason
            What exactly needs to be done to the bracket to run the E30 tranny with a 24v swap?
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • 325Projectz
              • Jan 2005
              • 1956
              I haven't done it myself but some say just run a motor mount on the drivers side for the tranny.
              Trent, i think is the person you want to talk to.
              91 m3
              • Jason89i
                • Sep 2004
                • 875
                the e30 getrag mounts at a 10deg +/- different angle. i kept the body/support mounting points and changed the trans/support mounting points. plasma cutter, welder. moved the passenger side mounting point down about 3/4" and move the other up. i looked for pics but couldnt find any. do a search, theres a lot of good info out there.
                Originally posted by 325Projectz
                I haven't done it myself but some say just run a motor mount on the drivers side for the tranny..
                i suppose you could try this, however.....you want to keep the transmission ouput "in line" with the diff. if the trans output is not in line (or raised) it will cause undue stress on the driveshaft.
                cheers, jason
                • 325Projectz
                  • Jan 2005
                  • 1956
                  I wouldn't try this, its too easy to make a bracket. I made a bracket on my last swap and used a zf on my m3.
                  But, they say it works, and this is r3v.
                  91 m3
                  • Jason89i
                    • Sep 2004
                    • 875
                    I haven't done it myself but some say ........
                    I wouldn't try this, ........
                    wait a minute. you brought it up.
                    if its not a viable option, dont bring it up.
                    cheers, jason
                    • 325Projectz
                      • Jan 2005
                      • 1956
                      Its not a matter of me not using it, its options available to others. Its like some perfer e30 m3 5 lug, some will run with e36 suspension. Same deal.
                      Its options and opinions.
                      cheers, sean
                      91 m3
                        • 37828
                        I'll probably end up giving the motor mount thing a whirl, see how it works. If not I'll just make something.
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • Lof8
                          • Oct 2006
                          • 2827
                          Let us know what you think about these options when you test 'em out.
                          thanks
                          S50'd
                          Originally posted by TDE30
                          What is this faggy shit I have happened upon?
                          I can always live in a M3. Can't M3 a house.
                          • e30ryan///m3
                            • Dec 2005
                            • 249
                            cheers, jason
                            For my ZF tranny which of the following numbers do I need? Also will the e30 m3 shifter work with the ZF trans? or do I need an e36 m3 shifter as well?
                            Thanks,
                            Ryan
                            • FredK
                              • 14752
                              You'll need 1, 2, 3, 7, 9, (4) of 10 and (2) of 11, 12, 15. The stock E36 M3 shifter SUCKS. Get an MZ4 or MZ3 shift lever and bend it. You'll need the rubber boot from the E30 (part number 8 in the diagram), NOT the E36. The E36 rubber boot is too big, as I found out.
