might be my motor!!! pictures!
  • mitch500
    • Jan 2006
    • 1092
    what do you guys think of this ?. compression numbers seemed low arent they supposed to be 190 across, is this only when the motor is warmed up because the numbers were 140-150 across all six cylinders with the motor out of the car cold.? oh and whats that black box to the right of the DME.
    http://i140.photobucket.com/albums/r...EEK/Clutch.jpg
    http://i140.photobucket.com/albums/r...yandClutch.jpg
    http://i140.photobucket.com/albums/r...SSNEEK/DME.jpg
    http://i140.photobucket.com/albums/r...NEEK/Plugs.jpg
    http://i140.photobucket.com/albums/r...EK/Engine1.jpg
    http://i140.photobucket.com/albums/r.../EngineTop.jpg
    http://i140.photobucket.com/albums/r...ineFront-1.jpg
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
  • browntown
    • Jun 2004
    • 3524
    If you do it on a cold motor, add some oil to the cylinder, and it goes up, then your rings might not be good. Doing a compression test on a warm motor will not reveal this as everything is nice and expanded with a nice coat of oil on the cylinder walls giving an artificially high result. This info is brought to you by unsubstantiated internet reading, and should not be taken as law.
    Now that I search there is decent amount of sites that tell you to do it warm too, in fact more than the cold. Huh. I'm no help.
    • mitch500
      • Jan 2006
      • 1092
      thanks,anyones else?
      1987 e30 325 eta
      1983 e28 533
      2001 x5 4.4l
      1991 Jeep XJ I6 4.0
      • grib
        • Oct 2006
        • 151
        You may want to get a better shot of those plugs - it is difficult to really see the tips in that light.
        What were your compression numbers? Not just the overall numbers, but the relation to each other is important as well.
        I have an S52 that appears to be in great shape (very clean head, oil pan and internals - but have not completed/started it yet) that tested these numbers cold:
        # 1 - 179 lbs
        # 2 - 175 lbs
        # 3 - 170 lbs
        # 4 - 173 lbs
        # 5 - 170 lbs
        # 6 - 174 lbs
        Bentley lists the compression specs as:
        Minimum Compression 142-156 psi
        Maximum Difference between cylinders: 7psi
        So "technically" mine would not pass (delta between 1 and 3/5), however 2 PSI could be attributed to error in the gauge. We'll see how it runs.
        1987 325i Cabrio - SOLD
        2014 Chevy Volt
        2007 FJ Cruiser
        • browntown
          • Jun 2004
          • 3524
          7 psi differential is like 5%, most things I've read say 10% variance is okay.
          • LINUS
            • 2422
            Before you get too far into thinking about buying parts, do yourself/have it at least leakdown tested instead of just a simple compression test. That way you'll find out if your problem is valves/upper end or rings/bottom end. If you are only doing this one time, paying to have it done might be the smarter money. I don't know what one costs, the shop I use lets me use all tools and a hoist on Saturdays for $15/hour. Just make sure the shop you use knows up front that this is for your own information, and that they aren't going to be doing the labor. Just to make sure you get an accurate result.
            It's not how you handle the good times, but the faith you keep in the bad that defines you.
            • mitch500
              • Jan 2006
              • 1092
              this is the last message the guy sent me, this is what he stated about the compresion test.
              "I did a compression test however my tester had seen better days.. it worked but gave me lower than expected numbers as it has done this before.. The engine ran awesome before so please don't let these numbers fool you.. 140-150 1 and 2.. 3 and 4 were down at 100-110 and 5 and 6 were around 140-150... again the motor ran great in the car so I am sure it's just the tester.. or i am not doing it right..?! Everything is there.. the oil is clean.. Let me know what you think..""
              1987 e30 325 eta
              1983 e28 533
              2001 x5 4.4l
              1991 Jeep XJ I6 4.0
              • Mike325
                • Mar 2006
                • 3685
                You should always do the comp test with the motor warm. Sounds like you should get the comp tested with a good tester.
                Originally posted by Kershaw
                • grib
                  • Oct 2006
                  • 151
                  If those are the actual compression numbers, I have a difficult time believing that the motor ran well. 100 to 150 is a huge difference between cyl. I guess you can hope that is gauge is malfunctioning? I'd pass on this one unless it is super cheap.
                  2014 Chevy Volt
                  2007 FJ Cruiser
