After getting my swap up and running, I've been thinking my car should be a little faster. I know this is all part of the "need for speed." But the car feels almost as fast as my E36 M3 when it should be faster (butt dyno inaccuracies aside).
These are the things I'm considering:
- Injectors
Right now I'm running the S50 injectors (17.5 lbs/hr?) that are pale green. Shouldn't I be running at least the 21.5 lbs/hr the S52 originally had? Or should I jump to 24 lbs/hr with the Euro HFM? What's the price differential? - Differential
I'm running the 3.73 LSD that came stock on my '89 325is. I'm thinking the 3.23 LSD from an e28 would allow the engine to run out faster since I won't be shifting gears every 2 seconds. - A tired engine
Is it possible the motor is tired? I doubt it since the motor had 107,000 miles at the time of swap. My M3 had about the same and ran fine.
