Eliminating ABS
  • trucupey
    • Feb 2007
    • 95
    Eliminating ABS
    I dont want this thread to be about wether I should eliminate the ABS or not. What I want to know is; the people that actually have eliminated the ABS how have you plumed it? If the master cylinder has 2 ports, have you used a divider block for the front calipers? Pictures and actual hands on experience would be gratly apreciated.
    Thank you.
    Alex
  • PiercedE30
    • Apr 2005
    • 4220
    yes, you can do it...........just run a "T" off of the front port and run your front lines that way......and throw in a biasing valve in there to adjust everything....
    My 2.9L Build!
