M50/M52 Swap
  • ReaverJam
    • Sep 2005
    • 11
    M50/M52 Swap
    Guys,
    I am at the tail-end of my engine swap (for the last 3 mths :) ) and have been baffled by one thing. How in the world do you guys install your engine, and manage to use the engine fan? I have a Spal Slim fan, about 2.25 inches, and it does not fit. I have no space.
    The engine is already pretty much almost resting by the firewall but the fan has no space. Help please!!!
    I must have done something wrong/different/silly during my swap. I can say this however, the darn connector for the engine fan (on the engine, the little nut thing) is in my way.....but even if I were to cut it off, I would not be able to fit the fan.
    Any ideas?
  • DEV0 E30
    • Oct 2004
    • 8892
    It sounds like you're trying to use it as a puller and the thread for the engine driven fan is getting in the way correct? Post a pic of your clearance, I think it just may be too thick.
    You could use it as a pusher in front of the radiator instead of a puller. That would probably solve your problem.
    • Brew
      • 3060
      I'm using the factory aux fan (in front of the radiator) with euro mounts that eliminate the A/C condenser.
      '91 318is
      • Mike B.
        • Jan 2006
        • 987
        Remove the engine fan/fan clutch assembly and a 2.25" slimline should fit.
        See post #122 - http://www.r3vlimited.com/board/show...t=71682&page=9 - Vlad has an electric fan on the engine side of the radiator with his euro 3.2.
        • ReaverJam
          • Sep 2005
          • 11
          Which mounts are the euro mounts exactly?
          • Brew
            • 3060
            Got to www.realoem.com input a euro e30 m3, go to "radiator", then "additional fan". Don't know if this link will work: http://realoem.com/bmw/showparts.do?...73&hg=17&fg=10
            '91 318is
