clutch/flywheel Q
  • gazellebeigem3
    • Jun 2005
    • 3712
    clutch/flywheel Q
    when using the 260, which do you have to use, the s50 flywheel/clutch or the m20 flywheel/clutch?
  • PeaveyBassist
    • Sep 2004
    • 3511
    m20 flywheel/clutch kit... Might have to shave some on the oil pan/flywheel for it to clear. This is based on 2nd hand knowledge though. So... wait till someone else replies. I just want to take a guess and see if I am right.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • PiercedE30
      • Apr 2005
      • 4220
      Go with the m20 flywheel/clutch with an M3 pressure plate, if using stock stuff. Should work like a dream.
      My 2.9L Build!
      • gazellebeigem3
        • Jun 2005
        • 3712
        well the thing is that i have a uuc flywheel and newer e36 m3 clutch so if i cant use it with the 260 ill have to get a zf
        • matt
          • 3731
          You can use it.
          Please guys... don't post if you don't know for sure.
          • gazellebeigem3
            • Jun 2005
            • 3712
            Originally posted by matt
            You can use it.
            awesome, this is great news! So then i would be using e36 t.o.b., pressure plate, etc?
            • PiercedE30
              • Apr 2005
              • 4220
              pressure plates go with what the flywheel was made for...ie: m20 flywheel, m20 pressure plate......m3 flywheel, m3 pressure plate
              My 2.9L Build!
              • matt
                • 3731
                Use the e36 pressure plate, flywheel, clutch disk, the throwout bearings are the same.
                • gazellebeigem3
                  • Jun 2005
                  • 3712
                  excellent, thanks for the info
