Another Wiring Question
  • PeaveyBassist
    • Sep 2004
    • 3511
    For all the people who have actually done the swap and wired it up themselves... I am THINKING about doing a swap down the road. Ive been looking at wiring diagrams and figuring out what all is in the C101 and what pin everything is and all that. Here is what I have come up with. I have a 1990 325is. Maybe doing an m50 non vanos, but this should be the body side of the C101. If anyone finds any flaws please let me know so I can write them down and correct my chart. Also let me know if you think it is correct. Thanks.
    C101 Connector, Body Side (1990 BMW 325is)
    Pin Wire Color
    1 Blu--- Alternator -> Instrument Cluster, ABS Control Unit (Charging Monitor )
    2 Blu/Blk---Oil Level Sensor -> Check Control (Pin 1, Lvl Full?)
    3
    4 Br/Vl--- Coolant Temp. Sender
    5 Blk/Br--- Oil Pressure Switch
    6 Grn/Yl--- Oxygen Sensor Heater Relay (from fuse 9)
    7 Grn--- Ignition Switch -> DME
    8 Yl/Wt--- Present Fuel Rate output -> MPG Gauge
    9 Blk--- Engine Speed (DME -> Tachometer)
    10 Vl/Grn--- Oil Level Sensor -> Check Control (Pin 2, Lvl Low?)
    11 Wt/Blu---Instrument Cluster -> Diagnostic Connector (Service Light Reset)
    12 Br/Blk--- Check Engine Light (DME -> Instrument Cluster)
    13 Vl/Rd--- Fuel Pump Relay
    14 Blu/Yl--- Speed Signal (Instrument Cluster -> DME)
    15 Blk/Grn---Unloader Relay -> Starter
    16 Wt/Blk---Srs -> Diagnostic Connector
    17
    18 Blk/Yl--- Ignition -> Starter (crank)
    19 Br--- Ground (oxygen sensor, diagnostic connector)
    20 Rd/Yl--- Main Relay - >ABS Hydraulic Unit
    Thank you,
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • PiercedE30
    • Apr 2005
    • 4220
    hey, i just made my wiring adapter a few weeks ago....for a '90 325i, with a e34 non vanos m50....if you need any help once you get into it, shoot me a pm and i will be more than willing to give ya a hand with it...lemme get my notes and i will help with your c101 in a little while.
    My 2.9L Build!
    • PeaveyBassist
      • Sep 2004
      • 3511
      If I get the m50 I am looking at... I believe it came out of an e36. I am mostly just wanting to make sure that those pins for the body side are correct. It will be a long time before I start actually working on putting it in. I plan on getting everything, then rebuilding the m50 before it goes in. When I do stuff I will definitely give you a PM if I have any questions though. I appreciate it. Let me know what ya find on my pins/wires/etc. Thanks!
      Will
      DaveCN = Old Man
      • vr4boy
        • 282
        pm sent.....
        • JoeMadoo
          • 936
          Were the colors the same on both sides of your original e30 c101 connection?
          '86 E30
          '05 E53 X5
          '72 Firebird
          '10 Prius
          '03 Tundra
          • So Live
            • 2512
            Check out www.addissimo.com for the e36 part go to the engine/power thing and click on e30/m50 wiring. I used his chart verbatum with my e34 harness in my 91 325i and it started! I know a few of the gauges worked too.
            -Chris
            • Mike325
              • Mar 2006
              • 3685
              That web site is fucking nice!!! Thanks for the link.
              Originally posted by Kershaw
              • So Live
                • 2512
                Thank Addissimo. Hes the fuckin man. Nice guy too.
                -Chris
                • NABR 1337
                  • Aug 2007
                  • 73
                  site down....8-11-07...
                  • gregslow318i
                    • Sep 2007
                    • 1918
                    still down 11-19-07
                    looking for a e30m50 swap harness adapter pm me $150 shipped
                    email nitroman12@gmail.com
                    • BlackE30
                      • Sep 2004
                      • 605
                      yea.... he didn't pay his hosting bill.
