tube from clutch cylinder?
  • Bimmer335is
    • Jun 2006
    • 146
    What does this blue tube get hooked up to? It's comming from inside my car, on the clutch slave cylinder or whatever. As you can tell, I'm using e32 booster with remote resevior. As far as I understand, I have to run it to my resevior, is this correct? And what did you do with it? Thanks for the help. I hope to get my car running this week.
  • trent
    THat goes to the brake fluid reseviour. That feeds brake fluid to the clutch master. You will have to bleed that system also.
    • Bimmer335is
      • Jun 2006
      • 146
      how'd you hook it up if there are only 2 holes in the resevior to do so and those two go to the brake mc.
      • Mike325
        • Mar 2006
        • 3685
        You may have to get a small res to feed just the clutch. That is a common solution to this problem and many cars come from the factory with a seperate res for the clutch.
        Originally posted by Kershaw
        • trent
          This is true. Most run the factory reseviour which has a obvious connection for this nipple. on the side.
