Anyone get a dualmass clutch cut?
  • stilllearning
    • 82
    I pulled the tranny off my motor and wanted to put in a new clutch. Wondering if anyone has successfully gotten a dual mass clutch cut? If not what do people do? get a new clutch every time?
  • mitch500
    • Jan 2006
    • 1092
    ive had mine resurfaced,
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
    • ZiMMie
      • Jun 2004
      • 968
      use an M20 Flywheel with clutch and pressure plate combo.
      www.stancefactory.com
      • FredK
        • 14761
        A dual mass can be reused once. You don't need to resurface it unless there is something seriously wrong with the surface, in which case you're probably better off buying a low mileage, used flywheel. Just clean off the gunk with some scotch brite, clean off the residues with some Brake Clean, and you're done.
        Dual mass flywheels are worth very little on the used market.
        • KangamangusDriver
          • Aug 2005
          • 1870
          Im with FredK
          I wanted to have mine machined for good measure, the machine shop said they were not able to do so since it was dual mass.
