What model can I find a diff from???
  • Mr.SWISS
    • Nov 2005
    • 1251
    I wnat something with little mod to work(cover, output flanges) that will give me about 3.25-3.55 in LSD. What is the most plentiful?
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
  • FredK
    • 14761
    The 3.25 is more common than the 3.46. Either way you're going to have to scour salvage yards, ebay, or the classifieds sections.
    Worst case scenario you can get a 2.93 from an eta for now, and swap to a better ratio later.
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      You want a 3.25, start looking at E28's, you just need to swap the rear cover and half shafts (easy job)
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • Mr.SWISS
        • Nov 2005
        • 1251
        I read the e28 535is has a larger case than all other, any trwoof?
        :nice:
        • Garageaholic
          • Dec 2005
          • 5204
          nope, same size. I got my 535i 3.25 from that car. I dont' know about E34 535i's though that had the same M30 engine.
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • NZM50SWAP
            • Feb 2006
            • 75
            Dude some e28 535's and all e28 m5's had large case differential's. These will not fit into a e30. Different mounting points on the subframe. Trust me I bought a large case for my swapped e30 and could not fit it without making serious modifications. The way to tell betweent the case's is large case has 8 bolts holding the side plates togetther(the part that bolts to the halfshaft) medium has 6 and small case that came on most 4cyl have only 4 bolts.
            hope this helps
            • Garageaholic
              • Dec 2005
              • 5204
              I stand corrected. How about this:
              Before buying an e28 535i 3.25 differential, ask for a picture of it so you know which one you are getting, bc apparently there is a large difference such that you could visually identify the discrepencies between the two.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              • SchnellerVert
                • Sep 2005
                • 3948
                Shop over on www.mye28.com they like 3.73lsd and maybe you will get luck with an even swap.
                • Garageaholic
                  • Dec 2005
                  • 5204
                  Good luck getting an account with them there. lol
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  • BigD
                    • Jul 2006
                    • 1085
                    I think the 2.93 will actually give you a stock E36 ratio because of the smaller wheels of the E30.
                    • FredK
                      • 14761
                      Yeah, the 2.93 will definitely give you great highway cruising.
                        • 37832
                        E28 or E24 diff is what you'll want.
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • NZM50SWAP
                          • Feb 2006
                          • 75
                          2.93 worked well for me. e34 2.5 m50 with e30 zf (yes that's rite it's a e30 ZF) gearbox m20 flywheel/ clutch /starter etc
                          Was good on open road but a little bit tall for around town in heavy traffic.
                          I could 193kmh outta 3rd gear
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            So Matt, will a S3.54 out of an M6 fit?
                            :nice:
                            • FredK
                              • 14761
                              I believe the E24 received a 3.64S at one point. The revs will still be pretty friggin high. An M6 diff should work.
