still confused about master/booster setup
  • gazellebeigem3
    • Jun 2005
    • 3712
    My car is swapped to five lug and with that im using a 750mc. I foolishly bought an iX booster not knowing if it would work with the mc, like the 320 does. i know that i have to use a remote reservoir with the ix, but im wondering if i can keep my booster when swapping to s50? shank you
  • LINUS
    • 2422
    There's some information floating around here that says the IX and the 7-er dual chamber boosters are the same part #, but I haven't seen this with my own 2 eyes yet. If you have a few minutes to go play on realoem.com, I bet you could verify that. I'm guessing your 7-er MC bolts up just fine to your IX booster, correct?
    It's not how you handle the good times, but the faith you keep in the bad that defines you.
    • matt
      • 3732
      Nope. Won't work. You need an e34 M5 master cylinder to match the iX booster. The 750i master cylinder works with the 320i and stock e30/i booster.
