lightest motor?
  • pizzle12345
    • Apr 2007
    • 3
    lightest motor?
    M50, M52, S50, S52... whats lighter? and what does the M20 weigh? Thanks guys
  • FredK
    • 14762
    The twin cam engines probably weigh within a few pounds of each other. They're pretty much the same in terms of castings and accessories. The only real difference would be the rotating assemblies, but even then, there won't be a huge difference in weight. I've hefted an M50 NV crank and a S50 crank, and they both weigh a lot (around 46? lbs).
    • SpecM
      • Oct 2005
      • 4531
      -An Al-block m52b28 from a z3 is the lightest
      1989 cirrisblau-metallic 325i
      • Jason89i
        • Sep 2004
        • 875
        http://www.bimmerforums.com/engine_faq/
        • pizzle12345
          • Apr 2007
          • 3
          not a huge difference i guess, might as well throw an S50/52 in there
          • Mr.SWISS
            • Nov 2005
            • 1251
            Originally posted by Jason89i
            great link, my car only gained 6lbs of engine weight since I used the 10lb fly.
            Originally posted by 325Projectz
            don't listen to the diagram... listen to mr. swiss.
            :nice:
            • e30pq
              • Apr 2006
              • 579
              What is the difference in weight between the M50/S50 duel mass flywheel and the M20 flywheel?
              • Mr.SWISS
                • Nov 2005
                • 1251
                I'm guessing about 25lbs.
                :nice:
                • FredK
                  • 14762
                  Nah, the stock s50 dual mass flywheel weighs 25 lbs according to JB Racing. I could have sworn the S50 dual mass fly weighs a couple of pounds more than the S52 fly.
                  Anyway, the difference in weight between a stock single mass M20 (18 lbs, not shaved) is actually closer to 7 lbs, not 25.
                  • Jason89i
                    • Sep 2004
                    • 875
                    Originally posted by FredK
                    Nah, the stock s50 dual mass flywheel weighs 25 lbs according to JB Racing. I could have sworn the S50 dual mass fly weighs a couple of pounds more than the S52 fly..
                    your both correct. some later s52's were equipped with lighter flywheels. material was taken off the edge between the dowel. flywheel kinda looks like a like a 6 - square - toothed wheel.
                    and then theres the s50b32 (euro) which is a couple lbs lighter than that.
                    cheers, jason
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      There is no way the dual mass fly I pulled off the M50 weighed 25lbs, that sucker was pretty heavy.
                      :nice:
