Wiring fiasco q
  • So Live
    • 2512
    Wiring fiasco q
    Hey everybody,
    Usually i dont post because i know how to search and read old threads but i decided i have to post. Ive been lurking long enough.
    So ive been putting together my own non-vanos m50 + ZF320 swap into my 91 325i for about two weeks. With all the resources, ive been able to get the whole thing basically squared away untill now minus the exhaust and the wiring. I basically copied Addismo's chart for my e34 harness. I finished the adapter today and turns out, it runs!
    After a few minutes of running, a green/blue wire decided to fry itself. It goes to one of the three aux relays. Its not the main one with the big power lead in it. Im guessing its the fuel relay but im not sure. It seems like the motor dosnt get fuel at all when the key is on but it gets fuel when cranking and running if that makes sense. Im not exactly sure why or how it happened.
    Any ideas?
    Thank you in advance!
    p.s. I also read something about the "unloader relay" but couldnt determine anything about it! What is it and do i need to wire something up, if so how do i go about doing that? What cars should need it?
    -Chris
