problem w/ swap/ booster...
  • new guy
    • Sep 2004
    • 467
    318is became a ALum M52B28 ---- start the car and the brake pedal drops and locks the wheels... turn car off then the car rolls just fine. Removed the booster vac line then the brake pedal doesn't move....(by itself) Curious to know why a booster could allow the pedal to be sucked in...
    Also have the 750 master 25mm if it makes a difference....
    thanks guys...
    Those that think they are, are not as they really are...
  • SpecM
    • Oct 2005
    • 4531
    -Do you have a check valve? W/o one I an see how it might do that
    1989 cirrisblau-metallic 325i
    • Mike B.
      • Jan 2006
      • 987
      Check valve
      • new guy
        • Sep 2004
        • 467
        I have a new one from the dealer in it... You think could be bad???
        • FredK
          • 14764
          Maybe the check valve is installed backwards? Probably not, but it's worth a shot!
          • new guy
            • Sep 2004
            • 467
            Arrow points towards engine... maybe bad???
            • Mike B.
              • Jan 2006
              • 987
              I would remove it and test it to see if it's bad.
              • matt
                • 3732
                The arrow should point toward the motor.
                • DEV0 E30
                  • Oct 2004
                  • 8904
                  I did that after pulling my engine once.
                  Took a good amount of bleeding after my stupid mistake.
                  • new guy
                    • Sep 2004
                    • 467
                    I have it in arrow towards engine... And just swapped a good one off another car... still problem. Bad Booster?
                    Maybe adjustment wrong on the push rod... I don't know just suggesting.
