need a new trans
  • thuibers
    • Jan 2005
    • 44
    need a new trans
    My Getrag 250 trans [93 325i] doesn't like to downshift into 2nd so it looks asthough I will either need to rebuild or replace, but I don't like the idea of putting in another used because I could end up with the same problem. I was told the e36 transmissions are known for this problem. I'm thinking it maybe a good excuse to put in a 6 speed. Not quite sure what drive shaft would work with a 6 speed so any help would be appreciated. Zionsvillle sells a kit, but if anyone has anything for sale let me know. I also have a friend living in england that might help source/ship. From what I have read I need a tranny from a 330i, z4 or new 5 series [zf gs6-37bz] or are there other modles with the 6? suggestions on what a good price to pay is?
    Thanks
  • asubimmer
    • 6482
    a 6spd is going to be about as much as a s50/s52 itself. I have heard that bmw doesn't sell the parts to rebuild the e36 trannys anymore, it may just be the zf's though...
    • equate975
      • Jun 2004
      • 3382
      Talk to funkmasta, I'm sure he has a few trannys on hand and can hook you up with a good deal.
      Rollin' with a Geistkuchen
      • matt
        • 3731
        You can rebuild them... but I wouldn't. Just get a used one from a wrecker with a warranty.
        • thuibers
          • Jan 2005
          • 44
          There is a 1998 e36 m3 trans for sale on ebay and it is close to where I live, can i replace my getrag250 with it and will the e36 325 driveshaft work. Or to rephrase is the m3 trans the same length as my getrag?
          • static
            • Oct 2005
            • 501
            ^^ i have 98 m3 ZF tranny and used 98 m3 shaft with no modifications, etc..
            btw, my 2nd has a crunch to it and i don't like it.
            • thuibers
              • Jan 2005
              • 44
              So to use a m3 trans i need the m3 drive shaft?
              • FredK
                • 14761
                Yes, because the Getrag 250 trans output flange has a 78mm bolt circle diameter. The ZF 310/320 output flange is 96mm.
                • So Live
                  • 2512
                  I have the zf box. It came out of a e46 99 328i and so did the driveshaft. They have the same part #'s as the e36 m3 parts. I think with the e36 m3 driveshafts, some of them had a 6 bolt diff flange while some had the 4 bolt one we need. Real oem has 2 part numbers for the driveshaft. I wouldnt buy a driveshaft if you cant tell what flange it has first. You could always swap the e30 diff input flange with the 6 bolt m3 one but why waste the time and money. Both work with the stock e30 CSB mounted backwards.
                  Something to think about: The ZF boxes have this problem where the shift lever sits in front of 5th when in neutral instead of in between 3 and 4. BMW has an $11 kit with a tube and a spring to fix the problem but i dont think you can do it in the car easily. Mine has the problem and its really really annoying but it comes and goes. I would say spend the money while the trans is out and fix it even if you think it dosnt need it because it WILL happen (from what i hear). Search the e36 m3 section on bimmerforums and theres a 40 or 50 page thread about the problem.
                  Good luck!
                  -Chris
