325i or 525i engine
  • nholm325e
    • Apr 2007
    • 78
    325i or 525i engine
    Im sure this is a big DUH, but does the 525i come with non vanos??
    Im about to order for an engine, but should i just get the 525i m50 engine so i dont have to change the oil pan and stuff as if i went with a 325i engine.
    Is there any drawbacks goin with the 525i nv, or its basically the same engine, besides the oil pan setup??
  • BeirBrennerE30
    • 2740
    the same... but the wiring harness is a bit shorter than the e36 one...
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • Funkmasta
      • May 2004
      • 7185
      But still fits just fine. Arguably the 5 series harness is better since you can easily retain your oil level function.
      525's came with non-vanos for 91 and 92
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • nholm325e
        • Apr 2007
        • 78
        thanks alot guys, what kind of issues could i have with the shorter wiring harness??
        Shorter where, to the ECU section??
        • Funkmasta
          • May 2004
          • 7185
          The E34 is a lot wider than the E30, so it's not really an issue...
          That Guy.
          • PiercedE30
            • Apr 2005
            • 4220
            I've got a motor from a 91 525i. I'm glad I went with that because I didn't have to mess with the oil pan. The harness isn't that much shorter since it is going into an E30 and shouldn't make too much of a problem, just make sure you give it a little tug when it goes into the glove box (if you are having problems with it).
            My 2.9L Build!
            • wastedincome
              • Aug 2004
              • 906
              :stupid: Since I gots a "spare" e34 w/ a m50 (non vanos) which I plan 2 sruff into the vert
              Wastedincome420@yahoo.com
              CURRENT STOCK LIST:
              00' e38 750iL HighLine=Highway Queen
              92' e30 318 vert=Aint going anywhere
              91' e34 535iM=Aint going anywhere
              91' e34 525iA=For parts
              92' e34 535iA=For parts
              • nholm325e
                • Apr 2007
                • 78
                It seems to me that alot of people that are doing the e30 swap go with the E36 325i engine and go through all the trouble to modify the oil pan setup.
                Why dont most people just go with the E34 525i engine and make their lives easier?? is it close to the same price from one to the other??
                Is their any other differences between the setup going with the e34 525i engine might interfere with that normally isent seen when doing the e36 325i engine??
                ----(or is basically the engine, head, manifolds, ect.. is all the same besides the oil pan setup??)
                Are the transmissions the same from the 325i to 525i??
                Hope you guys can help clear some things up for me, Thanks
                • Funkmasta
                  • May 2004
                  • 7185
                  More E36s get wrecked with decent mileages on them than E34's
                  That Guy.
                  • BeirBrennerE30
                    • 2740
                    there are way more e36s out there to get totalled....
                    e30sport.net
                    • So Live
                      • 2512
                      Tell me how! I looked around but ive heard you have to run all new wires to the engine/car harness.
                      -Chris
                      • e34john
                        • Apr 2006
                        • 3599
                        Harder to find an E34 but once found, there is a way better chance that it will be in better shape right? I want one from a 525 touring those probably didn't hit WOT daily. But then again the M50 in my e34 gets driven hard, and it is still smooth and runs great.
                        • So Live
                          • 2512
                          For sake of not making a new thread, ill bump this one.
                          So i aparently had the fuel consumption wire and the oil level wire switched in my harness adapter. Now the economy thing works but my oil level llight is still on and it pisses me off. Is there a way i can jumper the thing to see if my level sender is bad or if i have it wired wrong?
                          Thanks in advance.
                          -Chris
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            Thanks in advance.
                            I got the same thing and treehouse said I need a new level sensor...I think I will try to clean my old next ol change before I dump $100 on that check panel light.
                            Originally posted by 325Projectz
                            don't listen to the diagram... listen to mr. swiss.
                            :nice:
                            • So Live
                              • 2512
                              haha i know how you feel. Im pretty sure i have the harness wired correctly but im not exactly sure. I want to jumper the sensor and see for sure but i dont know how!
                              -Chris
