Why cant I run my M52 in OBD2 configuration on my swap?
  • FredK
    • 14763
    Thanks for posting, Skyliner, and welcome to r3vlimited!
    • 318isbmw
      • Nov 2005
      • 2843
      what about something like turner's EWS delete chip for the ecu? but the ecu must be a EWS one IIRC for it to work w/ the OBD2 setup.
      • jrez
        • Oct 2005
        • 71
        last i checked, there is no ews2 delete available for seimens dme's. This was from Turner motorsports. I think they did say it was available for Bosch stuff. You would have to confirm that.
        At the race track.
        • etxxz
          • Feb 2006
          • 2085
          Originally posted by Skyliner
          You can use all the OBDII stuff. Here is a couple of pics of my engine bay:
          Here is how you do it:
          http://wp1016621.wp027.webpack.hoste...240/f00240.htm
          It is from e30.de. If you are not good on the german, there are page translators out there.
          All you are gonna need is: (this stuff have to come from the same car as the engine; ie match with the ecu)
          EWS-II ecu
          Antenna
          Signal-booster
          Key
          Then you need to make 5-10 connections (depending on how much you want to have working; ie Diagnose and more) which is pretty basic stuff.
          The wiring is described detailed in the link. If you can't figure out the german stuff i can help with that...
          ... you are my hero. i've been looking around for a long time and most i've come up with is this:
          where pins 1 & 3 of the EWS module are reversed so says the ETM for my s52 (which i am atempting to keep obdII) They are basically say the same, ex. i never really understood the whole ignition loop thing, but now i do. Thank you!
          btw. the "Signal Booster" ~ Transmitter Module, doesnt need to be from the same car, neither does the ring antena. Key, EWS and ECU do need to be from the same car. just to clear things up.
          didnt mean to revive thread, the search button sucks i came across this thread by mistake
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • StereoInstaller1
            GAS
            • 22679
            Originally posted by RyanZ06
            Sounds like i'm screwed. I dont have the ECU/antenna/signal booster/key from the original car, as this was a "mail order" motor.
            Looks like I'll just have to pony up for the OBD1 stuff!
            EWS module and Key need to match, antenna and signal booster can be from any OBDII BMW, AFAIK.
            OK, since this link was posted I got the translated page here
            This wiring diagram shows 2 wires That I have questions about...What the hell kind of signal does the green wire (pin 18 on the ECU) get? Is it a digital signal, or is it a pulsed analog signal, or what? Obviously, that EWS module puts out something...
            Another question I have is can a EWS/key from an earlier BMW be used? Could you grab a EWS and key from a '95 525i to make a OBDII ECU happy?
            Closing SOON!
            Thanks for 10 years of fun!
            • EtaSport
              • 2853
              You have to have a valid VIN and registration to be able to get new EWS keys from the dealer. You can order the EWS module (they must be vin specific) and it will get the car started, but after it is installed it must be coded. The only problem is, you wont be able to get a key unless you know the previous owner.
              On new cars the keys have the digital passcodes stored in the transponders, and they are initialized by putting them in the ignition on KL15 for 30 seconds. The ews module does the rest. The only reason they are VIN specific is to operate the key tumbler. The key must match the EWS version though as the transponders use a certain AM (i think its AM) signal.
              Old and improved:
              • StereoInstaller1
                GAS
                • 22679
                Right, but what kind of signal goes from the EWS module to the ECU?
                Closing SOON!
                • SchnellerVert
                  • Sep 2005
                  • 3948
                  Info: posted prior to reading complete thread. It's possible as everyone has said.
                  • e304me
                    • Feb 2006
                    • 1374
                    yaaaay im a badass at searching
                    So its pretty much just like an obd1 swap except for the ews right?
                    any good wiring diagrams that can be used to figure out the rest of the wiring?
                    In theory, it seems much easier than converting to obd1, plus it can be used on engines where obd1 is not possible.
                    • EtaSport
                      • 2853
                      The EWS module sends the Individual Serial Number to the DME. The ISN is stored in the DME and the EWS. It is a digital signal via a data line. If the ISN match between the DME and EWS the DME will pulse injectors and fire the coils.
                      This differs from EWS I because there is no ISN on EWS I. The ISN is used in EWS III (3.2), but a rolling code is added in EWS III (3.3).
                      Old and improved:
                      • StereoInstaller1
                        GAS
                        • 22679
                        Fuck!
                        Closing SOON!
                        • EtaSport
                          • 2853
                          It is easier in the way that you already have your sensors and harness, but you have to add a lot more. It does seem to cost a lot to convert to obd1, but for some people it is still the best option. Depending on your emissions laws, some swapped cars require all the emissions equipment that was installed on the engine to still be there. So you'd have to run a secondary air pump, all the convertors, and all 4 o2 sensors. Obviously there are ways around it, and most states do not require this. But obd2 is still designed for 4 o2s which means sims may be required.
                          For most guys its just easier to do obd1, although i do think the Siemens systems are much better. And nowadays people cant even use the tuning card anymore as there are many tuners of obd2 cars.
                          Old and improved:
                          • EtaSport
                            • 2853
                            Fuck!
                            In theory, if you could determine the hex code of the ISN for the DME you are using, you could generate the signal artificially. However I wouldnt be able to tell you how to do that, or if it would even work.
                            Old and improved:
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              Why not just send off your ECU to have the EWS and rear O2 sensors disbled? It would definitely save you some headache.
                              My 2.9L Build!
                              • e304me
                                • Feb 2006
                                • 1374
                                can they disable ews with obd2?
