m50 out of a 91 525ia ?
  • Jean
    • 18228
    There is a totaled 91 525ia, would it be a good choice to pull the engine from or would I run into problems with wiring if it's an auto ?
  • Court M3
    • Jan 2004
    • 6713
    no prob at all wiring harness for auto and manual or pretty much the same IIRC
    Continuous For Sale Thread
    323i s50
    • Jean
      • 18228
      Nice!
      • Stu Mc
        • 4083
        Yea you'll need to gut the automatic ECU section of the harness out but other than that it's pretty much the same
        • matt
          • 3732
          Well, you can either do that or leave it.
          • Jean
            • 18228
            I am not sure on the condition, or mileage. I am going to run the vin through dmv and/or dealer to look for latest service record... I am going to pull atleast the head as I don't have easy access to a truck ... i'll drop the head off to a machine shop and go from there... i'll pull the oil pan probably too, as it's an e34 ..
            • asubimmer
              • 6482
              its no good, just give me the pan ;)
              • PiercedE30
                • Apr 2005
                • 4220
                the m50 from a 525iA is my starting base.
                My 2.9L Build!
                • Jean
                  • 18228
                  Great, I just wanted to make sure it's not any different than later versions. Would it make more sense to get correct wiring harness from a manual car with an ecu also, or is the difference only in the wiring or ecu ?
                  Hopefully head is straight and not cracked or damaged, we'll see.
                  • matt
                    • 3732
                    Auto/manual makes no difference in the ECU and the wiring harness works the same either way.
                    Just remember to install a pilot bearing if it was an auto.
                    • Jean
                      • 18228
                      What size sockets are used on the m50 head, just usual metric stuff or anything special like torx or hex ?
                      • matt
                        • 3732
                        Yes and yes.
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          Use inverted torx sockets for the head bolts and timing chain tensioner.
                          My 2.9L Build!
                          • Jean
                            • 18228
                            My inverted torx sockets didn't fit, they weren't thin enough :(
                            • matt
                              • 3732
                              You need the special one for the head bolts. The one on ebay.
