I recently finished my S50 engine swap. The car would start but it wasn't running properly since the O2 sensor wasn't installed yet. I just got my car back from having my exhaust installed.
The car is running rough. I did the pedal trick and it flashed code 1226. I understand that could be a knock sensor problem. Before I do that I wanted to ask a simple question.
I used my M20 O2 sensor in my OBDI E36 cat. Is the M20 sensor the same as the S50 O2 sensor?
I also have an issue with my VANOS unit. The VANOS seems loud. Outside of a VANOS replacement what are my options to troubleshoot the VANOS?
I appreciate any input.
Paul Q
Paul Q
