e34 oil level sensor delete panel?
  • asubimmer
    • 6482
    I bought a new e34 oil pan and obv it didn't come w/ an oil level senor. And there really isn't a point to me buying one b/c from what I read you have to have a e34 harness to wire it in and its not really that importaint anyway. So I heard there was an oem delete panel that just covers the hole. I called up my local stealership and they found the part in their pictures but there isn't a part # for it and they didn't know what to tell me. What do you guys do? Does anyone know that plate's part # or should I just make something lol.
  • matt
    • 3732
    Your local dealership parts guys are not real sharp are they?
    Cover Lid - 11 13 1 726 357
    O-ring - 12 61 1 277 129
    Matt
    sharp dealership parts guy
    • asubimmer
      • 6482
      ha thanks, did you do this w/ your swap?
      • Mr.SWISS
        • Nov 2005
        • 1251
        I may have a sensor I can donate, unless Miracle Matt or FredK da Sensei has a trick to unstick the float and make mine work. ;)
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • matt
          • 3732
          I used the block off dealie.
          • asubimmer
            • 6482
            cool deal
            I found out that turner makes a plate that fits there too, so you can put in an oil temp sensor. Its real nice but its like $80 lol. Do you remember how much the bmw plate is matt?
            • matt
              • 3732
              $10 ish
              • FredK
                • 14762
                FredK the Sensei sounds a lot cooler than Miracle Matt. I mean, what kind of miracles does this guy perform, besides telling you to RTF(ET)M!
                :finger: :jk:
                Unfortunately he came through already on the blockoff plate. I have a similar situation with a coolant level sensor that's sorta gummed up and works when it feels like working.
                • trent
                  drill and tap the fucking plate for an oil temp sensor, big whoop
                  • matt
                    • 3732
                    The TMS one is neato because it keeps the sensor off the pavement...
                    I dunno about you but my pan is fucking low.
                    :finger: :jk:
                    You noticed my style!
                    Check panel sensors are for the weak. Check your oil and coolant once a week or something. Just make sure you check your coolant cold... that can be messy....
                    • trent
                      then drill and tap the side of the pan if you are scared
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        To me it's all about having everything neat and functioning like it was pre M50. This to me is a mod, not a trade off.
                        :nice:
                        • 1990m3
                          • 1180
                          if you start with a 318is then you don't have to worry about any of that stuff, they were stripped down pretty good. I don't even have tweeters in my door :(
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            I didn't either when I started. 89 325i's were not exactly loaded.
                            :nice:
                            • Sirjustinderek
                              • Jun 2014
                              • 143
                              Did OP end up grabbing the delete plate from the dealership? ECS also sells it
