slave/master cylinder for m50 trans
  • nholm325e
    • Apr 2007
    • 78
    I know this is probably a stupid question but... if im using my e30 master cylinder, and i am using the m50 trans, is there anything i have to change in order for the e36 slave to work with the e30 master??
    --Or do i just use the e30 slave(im guessing probably not though)
    Thanks, -Nick
  • matt
    • 3731
    e36 SLAVE cylinder. Nothing else needs to be changed (master, lines, ETC). e30 one will not work.
    • PiercedE30
      • Apr 2005
      • 4220
      Any "upgraded" master cylinder's that we can use with the 260?
      My 2.9L Build!
      • Mr.SWISS
        • Nov 2005
        • 1251
        MEh I used the E30 master and E36 slave with a UUC line. Clutch feels good and stiff. I did spend $720 on my clutch fly kit though. :loco:
        Originally posted by 325Projectz
        don't listen to the diagram... listen to mr. swiss.
        :nice:
        • nholm325e
          • Apr 2007
          • 78
          Originally posted by matt
          e36 master cylinder. Nothing needs to be changed. e30 one will not work.
          The e30 master wont work with the e36 slave..?
          I ordered a pre modified 320i booster from a guy who stips down cars from down south, does the e36 master hook right up to that modified booster?
          --or should i just not waste my time and just use the e30 master-e36 slave
          • matt
            • 3731
            Shit sorry... got that backwards. e30 master, e36 slave.
            • matt
              • 3731
              We are talking clutch hyrdraulics... nothing to do with the brake booster.
              • nholm325e
                • Apr 2007
                • 78
                ohhhh my bad Matt, i misread your first post about the SLAVE, i thought it said master.
                Thanks alot
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  Thanks alot
                  The clutch system has a master(takes pedal force and uses a piston to pressurize fluid) and a slave cylinder(takes pressure and converts it to force). If you are using the E36 trans then you want to use the reg old E30 CLUTCH master cylinder and the E36 CLUTCH slave cylinder. The brake booster is all together another system.
                  :nice:
                  • triggrhaapi
                    • Feb 2007
                    • 350
                    Hey, just off topic a bit, what are you guys doing for a reservoir for the clutch fluid? The old system shared the reservoir with the brakes, but the remote reservoir I got per the brake booster thread has no port for it. I'm debating trying to plug the holes and mount the old reservoir for the clutch only.
                    1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      Accent res?
                      :nice:
                      • matt
                        • 3731
                        Look for a 2002 or e28 brake fluid bottle.
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          I would think damn near any JDM car will have a res with a bracket you COULD use.
                          :nice:
                          • matt
                            • 3731
                            A lot of them mount the res on the master like e30s do.
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              I know for certain the 95 Hyundai Accent has a independent clutch res.
                              I had one.
                              :nice:
