Full tank of gas makes my car barely run.
  • mazur
    • Jan 2006
    • 731
    Just recently got my car running. It began with a half tank of gas. It ran great and was very quick. This morning I drive it several miles to a gas station.
    I filled her up all the way and after maybe 30 seconds of driving it startting hesitating real bad and begin to sound like it was misfiring and wouldn't accelerate and then it would just die. After turning it back on it would be fine again for only 30 seconds.
    I don't understand it. How can it run perfect for a little while each time after restarting it? And it seems to rev fairly fine when not under load.
  • backtrail69
    • Jul 2005
    • 4471
    Bad gas?
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Mr.SWISS
      • Nov 2005
      • 1251
      What O2 are you using?
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • mazur
        • Jan 2006
        • 731
        Originally posted by backtrail69
        Bad gas?
        No...this is the best gas in town. It is not pinging.
        • mazur
          • Jan 2006
          • 731
          Stock E30.
          • static
            • Oct 2005
            • 501
            check your maf and vacuum leaks. Also, (for whatever reason ) you might not be getting enough fuel to the rail (pump, filter, etc)
            Try resetting your ECU too.
            • mazur
              • Jan 2006
              • 731
              No vacuum leaks that I can detect. Just switch out my chip and same thing happens. It seems like the fuel pump is not up to the task of supplying the fuel. The car runs fine right after startup probably because the fuel pump primes the rail.
              I let it idle for a bit then tried to start driving. Starts falling on its face just trying to get rolling in first!
              Can just having a larger mass of fuel in the tank affect pump output like this?
              • bdi_fc
                • 273
                If you haven't changed the fuel filter lately, do it, even if you don't think it's the cause of the issue. It's quick and easy.
                E30 Wiki: e30dohc.com/wiki
                • Mike B.
                  • Jan 2006
                  • 987
                  My guess would be bad gas, clogged fuel filter, or faulty fuel pressure regulator.
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    Also the E30 O2 sensor has different parameters than the M/S50 motors. Unless the car was an M42.
                    :nice:
                    • mazur
                      • Jan 2006
                      • 731
                      That might be so, but the car was running perfect for two days till just this morning.
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        how could the e30 o2 sensor be any different than the m/s50? it puts out a 0-1v signal no matter what (both m20 and m50). it doesn't matter which o2 sensor you are using (obviously with the exception of a wide band).
                        My 2.9L Build!
                        • e30polak
                          • 6136
                          it might be a prob with the fuel lines/sensor used in the e36's evap system that may cause this, but don't quote me cuz i might be wrong
                          INSTAGRAM: @UNDR8D_EMPIRE
                          • triggrhaapi
                            • Feb 2007
                            • 350
                            Here's what I would do: siphon out half the tank and see if it changes how it runs. If so, then you've isolated the problem being the pump, otherwise you'll want to check your fuel pressure regulator, then check the car for CEL codes.
                            1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
                            • euroshark
                              • Apr 2006
                              • 3491
                              Are you stopping the pump as soon as it clicks? If you are pumping after the automatic shutoff like a lot of people do... *click* - *pump* - *click* - *pump* -*click* - *pump*... you may have flooded the expansion tank for the fuel system, and this could be part of the problem... Maybe.
