How do you compensate for poor weight distrobution?
  • Ahheck01
    • Aug 2004
    • 185
    The fact that the M50 or S50 would be significantly heavier than my M20 is a big turn-off. These cars are already front heavy - I would think these swaps would throw that off quite a bit.
    Even if you even it out by adding weight to the rear, aren't you killing the biggest advantage to the e30 - the light-weight-ness?
    I'd like to consider an engine swap, but I need convincing that there's a solid way to address this issue.
    -Evan
    1992 525i 5speed: Sold :: 1996 328i 5speed: Sold :: 1997 540i 6speed: Sold :: 1995 M3ti 5speed: Sold :: 1997 328i 5speed: Sold ::
  • matt
    • 3732
    It's not significantly heavier. If its 50lbs, I'll eat my hat.
    I ditched my AC and power steering. The AC condenser is very far forward, and the compressor is very heavy. I just didnt' feel like putting the PS pump in.
    Add all that to a lightweight flywheel and an auto to manual swap and my car rode about an inch higher in the front after the swap.
    • Ahheck01
      • Aug 2004
      • 185
      M20: 258lbs
      M30: 315lbs
      M50: 299lbs
      M52: 260lbs (alloy) 308lbs (iron)
      S50: 300lbs
      S52: 308lbs
      S14: 234lbs
      So, to go to an S50 would be to add 42lbs, plus whatever the rest of the drivetrain adds.
      -Evan
      • asubimmer
        • 6482
        its not much more at all. The m42 is 220lbs if you want to add that to your list.
        • euroshark
          • Apr 2006
          • 3491
          M30 is 316lbs
          If you remove the AC components, you should end up slightly lighter in the front, or maybe come out even. The fact is that even if you add a solid 50lbs to the front, you probably won't notice with the correct suspension enhancements. There's a thread in the M30 swap section where I outlined some Alpina B6 and B6S specs. Alpina simply fitted slightly heavier duty OEM springs to the front of the B6S (based on the M30 M3), the springs were from the M3 with optional air conditioning, and obviously the B6S did not have AC. All of the road tests agreed that handling was unchanged, with just a tiny hint more understeer at the limit.
          Edit: The significance of everything above is that the M30 is considerably heavier than the S14... lol, how did I forget that.
          • Ahheck01
            • Aug 2004
            • 185
            Originally posted by euroshark
            M30 is 316lbs
            I definitely don't want to get rid of A/C.
            Will the getrag or ZF trannies add a considerable amount of weight? Just curious. I'm seriously getting interested in a potential swap.
            -Evan
            • euroshark
              • Apr 2006
              • 3491
              Real men don't need AC... you have windows that open!! lol
              Eh, if you keep it you keep it... Whatever works for you.
              The transmissions shouldn't be considerably heavier, maybe 15 to 20lbs at the high end, but I doubt it's that much.
              • kolunda
                • Mar 2007
                • 136
                A carbon fiber or fiberglass hood up front will drop some weight from the front end. If you go s50 and get some shorty headers that will save a few pounds also, maybe like 5. Remove the fan and clutch with a fan delete mod, umm.... remove the ABS pump and have non-ABS brakes. Lets see what else... Aftermarket lightweight pulleys... maybe a pound or 2 there... thats all I can really think of right now, so with this stuff your lookin at about 20 for the hood, maybe 5-7 in the headers, about 20 in the abs pump, and the pulleys maybe 1 lb. So thats like 48 lbs right there, bringing you down to m20 weight. TBH the biggest problem I have with my s50 swap and the handling, compared to the previous m42, is the fact that the extra weight sits farther in front of the front struts compared to the 4 cylinder, which makes it a bitch. But my car can still out-handle a lot of cars, and if you splurge on like a korman wide body kit, that'll knock even more weight off the front end and the car as a whole and bring it back down to stock levels (at least for a 318iS).
                Perot isn't a Hillary hater, but he's not a fan either, relating the bumper sticker he received that reads: "Monica Lewinsky's Ex-Boyfriend's Wife for President."
                • PiercedE30
                  • Apr 2005
                  • 4220
                  Anyone thought about splurging for an electric power steering pump? Wouldn't be a problem if you have one of the 140 amp alternators.
                  My 2.9L Build!
                  • trent
                    -Evan
                    Dude, get over it, there is no issue.
                    My car is 53/47 front rear with a/c.
                    • matt
                      • 3732
                      Not worth it at all... won't save any weight, PITA to get to work, might as well just delete PS altogether.
                      • BimmerToad
                        • Sep 2004
                        • 1537
                        I used to be obsessed with weight distribution when I had the M42 in, but seriously, fuck it. Most 'balanced' BMWs are slightly front heavy anyway, regardless of what you read in the brochures. I'd rather take torque and stiffer springs up front than questionably better balance. IMHO the swap does not remove the tossability of the E30
                        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          accordin to http://www.bimmerforums.com/engine_faq/ s50 weighs 333 lbs meaning your addin 75lbs to the front end. you could add ballast to the rear to compensate slightly. in reality thouh would you really notice? i mean a tank of gas weihs like 120 lbs so your weight dist. is always changing unless you keep your fuel level the same all the time
                          '89 Alpine S52 with goodies
                          • Ahheck01
                            • Aug 2004
                            • 185
                            That's the Euro S50. The US S50 is the same weight as the US M50. Look again.
                            • Mr.SWISS
                              • Nov 2005
                              • 1251
                              Werd..
                              I just ditched , my dual mass for a single mass lightweight fly and my car doesn't sit any lower. If anything I gained ~20 lbs up front but that brought ~40 more hp and 5 more MPG. I be very happy with the results, it seems like the car handles better now than before.
                              Originally posted by 325Projectz
                              don't listen to the diagram... listen to mr. swiss.
                              :nice:
