Using a Porsche 944 booster
  • FredK
    • 14762
    Weird. I can lock em up, but only with a lot of force. I have 320i/25mm MC/E30 M3 brakes.
    I'm gonna run this 944 booster with a stock Girling MC. I just installed it an hour ago, hopefully I can drop the engine in this long weekend.
    • cheades
      • 632
      That guy has something wrong with his brakes if he can't lock them up with the 320i booster, or he weighs about 50lbs.
      • So Live
        • 2512
        +1 i can lock mine but it is hard. then again im on shitty kuhmo 195's with the TMS brake kit.
        -Chris
        • e30polak
          • 6136
          with the 320i booster, u want to get a vacuum reserve canister, to add to ur brake assist...i did this and it made for much better brake feel and less effort to lock up
          INSTAGRAM: @UNDR8D_EMPIRE
          • So Live
            • 2512
            Good call. Whered you get yours and where did it mount?
            -Chris
            • Mike B.
              • Jan 2006
              • 987
              Check the last page here - http://www.r3vlimited.com/board/show...647#post739647
              • FredK
                • 14762
                For fitment, I'm using an M5 driver's side mount, and I had to shave the last four fins of the intake manifold to get it to clear the brake booster.
                In terms of master cylinder / brake fluid reservoir clearance, there is plenty of space between the TPS cable and the fluid reservoir.
                • ColdAccord
                  • 5926
                  damn. only junkyards 'round here are old american cars, and I'm not even in the south
                  Originally posted by blunt
                  • matt
                    • 3732
                    I have no problem finding almost any sort of german hardware in the yards around here...
                    • FredK
                      • 14762
                      OK, the car's now running and I broke in the pads.
                      It feels pretty close to stock. The diameter of the brake booster is around a quarter of an inch to a half inch larger than the 320i booster, so I had to shave the last four fins of the manifold AND I had to run around 4 mm of spacers on the driver's side engine mount. Friggin spacer city here.
                      It's not really any harder to lock them up with street pads (Pagid) and street tires (205/55R15 Potenza RE750) than stock, IMO. I don't have any unfettled E30s to test out this theory, though. There's definitely less pedal effort than my other 320i/25mm MC/M3 brake system.
                      • Mr.SWISS
                        • Nov 2005
                        • 1251
                        Hmm.....
                        Originally posted by 325Projectz
                        don't listen to the diagram... listen to mr. swiss.
                        :nice:
                        • So Live
                          • 2512
                          Interesting...
                          -Chris
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            I had an 86 944(the updated one) in 99 when I was 19 in Dallas, and while the toughest thing to do on it was a clutch and timing balance shaft belt job it was a pretty simple car. I do remember it did require QUITE the effort to lock up on dry pav though. I'm glad I got rid of that $$$ pit. Wai!!! I spent more on the E30's !!!
                            :nice:
