Cluch cylinder hose?
  • kroberts
    • 680
    Which one is usually used with the swap, E30 or E36?
    Either? Neither?
    (Both?)
    kr
  • Van Westervelt
    • 9365
    what hose do you speak of? res to master? master to slave? and what tranny are you using?
    • kroberts
      • 680
      Ooops. Master to slave on a ZF 5 speed. '97 S52.
      Any links for a braided hose?
      kr
      • FredK
        • 14753
        Sure, use a UUC Motorwerks E36 325i clutch hose with the 325i slave.
        The E30 clutch hose needs to be bent back so that the hardline that meets up with the slave cylinder is more or less straight. You can avoid this monkeying around by getting an E36 clutch hose.
        • Van Westervelt
          • 9365
          Or you can just have one made. I just had one made the other day. Cost me $40. Braided with a plastic coating.
          • matt
            • 3731
            The UUC one would have cost you $30.
            You can use either of the e36 slave cylinders, but either way you need an e36 325i hose.
            If you're using an M3 clutch: The M3 slave cylinder will give you a stock-ish soft pedal, the regular e36 one will give you a very stiff pedal.
            • Mr.SWISS
              • Nov 2005
              • 1251
              Another vote for the UUC hose. My only other mod aside from the lightweight flywheel. (unless the M50nv counts as a mod.):D
              Originally posted by 325Projectz
              don't listen to the diagram... listen to mr. swiss.
              :nice:
              • Van Westervelt
                • 9365
                I despise UUC after they have treated me like shit on multiple occasions.
                I also didnt have to wait for it to get shipped, or pay for shipping.
                • So Live
                  • 2512
                  Im rockin the s50 clutch/flywheel/trans and the m50 slave and i like the feel. Its nice and stiff.
                  -Chris
