Failed emissions - for those states that care!
  • david55838
    • 141
    Besides a power chip, non-stock AFM and maybe a bad O2 sensor, are there any other causes for an S50 to run rich and go over the limit on the HC and NOx readings?
    Thanks!
    Cheers,
    David
    '89 318i Touring (gone, but still loved) :sad:
    '88 Vert
  • dougsic
    • Jun 2006
    • 284
    Are you using the stock catalytic converters?
    • 1990m3
      • 1180
      David - contact me offline and we can meet up. My car passes emissions very easy. I'm sure we can figure out how to make yours pass as well. You may need the charcoal filter assembly but I'm not sure.
      check your PM
      • david55838
        • 141
        They're some aftermarket cats. An emissions repair approved shop in the area quoted me $3600 :crazy: to source E36 M3 cats, fabricate them and weld them in closer to the exhaust manifold.
        I need another idea!
        Cheers,
        David
        '88 Vert
        • iflytii
          • Jun 2004
          • 482
          Have you checked to see if you are throwing codes? I was running super rich until I got all my codes cleared. A bad knock sensor was the main culprit for me, causing the computer to go limp... :(
          • Jason89i
            • Sep 2004
            • 875
            might want to check the engine temp sender. i had that connector go bad once. i had it hooked up to a scanner were you could see ALL the sensor inputs while the car was running. sure enough, the dme thought the engine was 0deg at warm operating temp. wiggling the connector and you could see the temp jump up to 140deg. bad connector, engine was running rich thinking it was a cold engine. just a thought. cheers, jason blackhawk the 13th?
            • david55838
              • 141
              I'm code free, so the knock and o2 sensors were ruled out.
              I need that scanner! I might try for a waiver at the DMV tomorrow. No BHF on the 13th. Can't get off work. Enjoy!
              Cheers,
              David
              '88 Vert
              • Jason89i
                • Sep 2004
                • 875
                ryan can hook the scanner up over at the little car shop. not sure if dennis has it at alpine, might be worth a call. dealers typically have them too. i had another car scanned (with the euro motor) over in schaumburg. very cool to watch the screen and see everything the dme is processing. cheers, jason
                • surebimmer
                  • Jan 2004
                  • 978
                  High hc is inburned fuel. How are your plugs? Just BC you don,t have a code for the o2 sensor doesn't mean its working as good as is could be.
                  • matt
                    • 3732
                    O2 sensor could be it. NOx is high combustion temps, which can be caused by running lean, running too much ignition advance (chip), or the car overheating. How are your coolant temps on the rollers?
                    • david55838
                      • 141
                      I suspect the O2 sensor, but the shop I just had it to wouldn't say if it was an issue. They told me I need a 'post-cat' O2 sensor wired in as well as the 'pre-cat' one that's already there. I suspect that's BS.
                      I had to put the electric cooling fan on when the car was on the rollers, but it stayed at operating temp during the test.
                      Cheers,
                      David
                      '88 Vert
                      • 1990m3
                        • 1180
                        i don't think two o2 sensors will yield any improvements on an OBDI system. The ECU is designed to read from one o2 sensor. OBDII cars are designed to read from two o2 sensors.
                        • surebimmer
                          • Jan 2004
                          • 978
                          How old are your plugs? How many miles on the motor? How old is the o2 sensor?
                          • david55838
                            • 141
                            The motor has about 60k, and the sensor and plugs are no more than 2 years old. However, I went back this morning and a very 'helpful' tech got the car to pass! :pimp: So, me be done for two more years!
                            Cheers,
                            David
                            '88 Vert
                            • Van Westervelt
                              • 9365
                              Lucky man! :) Mine passed first try with flying colors, and its a 130k miles block, stock internals with 24 lb injectors with an afpr.
                              I wonder what tricks the mane used? hehe
