it's from an alpina B10
3.5" inlet, drop in filter... woo hah!
Originally posted by Holland
There should be a restraining order to keep kids 100 feet from that car at all times. Plus execution on the sight to anyone who places a shopping cart within 200 feet of the thing.
well, the way i see it fitting, is obviously flipping it around, from the direction it's facing in this pic... the intake tube would then be facing straight down near the fender well.. i can then run a piece of flex tube from there to a spot in the grille, or in the valance..
think i can just stick a plug in that smaller opening?
pardon the quick and dirty photochop... just wanted to illustrate my grand vision... ;)
c'mon.. no other input? I'm open to suggestions...
then i will probably be bummed if it does not fit.
I understand plugging that stray hole because of warm air, but I'd at least cut it flush back at the housing & fg - resin in a patch - or even leaving the hole - if the inlet hole on the pre-filter side is the same or smaller than 3.5" like the filtered side.
Like etasport asked - does this interfere with the ABS controller location? Have you deleted yours?
It's not how you handle the good times, but the faith you keep in the bad that defines you.
yeah, planned to cut it back and make it look more tidy...
im not sure if it will interfere.. still dont even know if it will fit.. still waiting for it to arrive!
i havent deleted mine, although for some reason, it has not worked since the swap.. not sure if i like it tho, without the ABS... i have locked em up twice in sketchy traffic situations.
