How to Properly Install CSB
  • ZiMMie
    • Jun 2004
    • 968
    jst wondering if anyone could help me out and reinstall my Center Support Bearing Properly.
    the problem is, it doesn't bolt up straight with the holes on the body. i have to slightly tilt it for it to fit properly and that even, it will be sitting right on the edge of the wholes rather than in between.
    J st for reference, im running an e36 Getrag tranny with the extended E30 drive shaft.
    has anyone else experience something like that during their installation?
    www.stancefactory.com
  • backtrail69
    • Jul 2005
    • 4471
    I pressed mine on with proper sized exhaust pipe and put the C clip back on. If the C clip fits it should be on all the way. Make sure it is preloaded and you have it on the correct direction.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      i paid a machine shop $10.
      • ZiMMie
        • Jun 2004
        • 968
        i think u guys misunderstood my question.
        I didn't remove the CSB from the rear shaft since it still looked like new.
        its just that after i installed my new motor/tranny, it doesn't line up perfectly straight with the bolt holes on the body. and when it does, it sits right on the edge of holes which doesn't make it straight.
        • matt
          • 3732
          Yeah, I had that problem too.
          I just bolted it up. :dunno
          • ZiMMie
            • Jun 2004
            • 968
            and how many guibos have u been thru. :D.
            but there gotto be a proper way to do it.
            how many miles have u put on ur swap, and any sign of wear on it?
            • matt
              • 3732
              500 miles or so. Haven't checked it.
              I will be installing an e36 driveshaft whenever I get a chance.
              • ZiMMie
                • Jun 2004
                • 968
                so anyone else?
                • So Live
                  • 2512
                  Maybe backwards? mines in backwwards but i have the 99 328 shaft.
                  -Chris
                  • ZiMMie
                    • Jun 2004
                    • 968
                    it cant be backwards.
                    I never removed it from the rear shaft!
                    • ZiMMie
                      • Jun 2004
                      • 968
                      bump!
                      • evil_twin
                        • Nov 2007
                        • 2965
                        So reviving this thread. If I am using a 328 drive shaft from an E36, I have to install an E30 CSB backwards?
                        Paypal: vdang5@gmail.com
                        Delta Auto Care
                        2875-C Towerview Road
                        Herndon, VA
                        703.435.1375
                        My Feedback Thread: Evil_Twin
                        • mattdk318i
                          • Jun 2006
                          • 3953
                          did you preload the bearing?
                          • mattdk318i
                            • Jun 2006
                            • 3953
                            not that i know of, I was told this repeatedly and when the day came it went on the same way as stock (for E30)
                            • kroberts
                              • 680
                              There are two CSBs for E30s. An early and a late. The cut-off date was late '87 IIRC. I have an 88 M3 with a 6/87 build date and my car took the early CSB.
                              Are you sitting down?
                              The early CSB costs about $140
