Vac line on TB..
  • sky_captnE30E36
    • Apr 2007
    • 23
    Vac line on TB..
    Ok,thought i had everything done.. had to pull the manifold once more, and noticed there's a vaccuum fitting on the throttle body itself.. Cant beleive i havent noticed it...
    Where does it go to?? I know the fuel press. reg. feeds off the manifold,along with the booster...
    Oh, and one more thing.. There's a hot lead coming out of the E36 harness "box" on top of the engine (driver side).. I opened up the cover, and that wire is spliced into another lead.. The question is where does that wire go? Its constant hot, so not too good when touches ground..
  • FredK
    • 14764
    Yes, the rightmost nipple is a vacuum fitting that goes to the check valve for the charcoal canister.
    The starter wire splits into two wires inside the harness box. The fat wire goes to the starter, and the smaller wire goes to the fuse box on the E36. However if you retain the E30 fuse box power cable, this cable is unnecessary. What you can do is to just terminate the floating power cable on the starter's fat lug as well.
    • sky_captnE30E36
      • Apr 2007
      • 23
      Awesome. I actually modified the manifold to fit the stock booster, and as a result put in a new "nipple" for the pressure regulator, and the charcoal canister.. So i'll just cap this one off.. And on the power lead, guess i'll just terminate it like you said.
      Appreciate the input!!
