Are this #s any good (comp).
  • svn2002s
    • Sep 2004
    • 479
    Buying an S52 and we got the following:
    1 160
    2 165
    3 155
    4 175
    5 155
    6 155
    What do the experts say?
    TIA
  • FredK
    • 14762
    Was it warmed up? How may cranks got you those results? I'd say if you did 3 cranks on a cool to warm engine, that those numbers are fine.
    Otherwise, hot, the engine should be blowing more evenly and slightly higher.
    • matt
      • 3732
      Might be a little low. I would not worry about it.
      When you have 0-100s on most cylinders... then you have a problem. BTDT.
      • So Live
        • 2512
        My m50 made more than that cold. It seems low to me. My buddys s50 makes about 215 across all 6.
        -Chris
        • Skafrog
          • 1732
          Ditto. Should be ballpark 215 if you are doing the test right. Are you cranking it enough?
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
